我跑了24小时。
用温度数据采集系统进行测试。 在此期间,3458A正在读取大约的欧姆。 300个多路复用通道。 我想知道我是否可以设置3458A在24小时内记录3458A的内部温度。 我想在我的测试时间内验证它已经超过±1°,因此我可以保持24小时的准确度。 如果是这样,这将中断ohmf的操作。 以上来自于谷歌翻译 以下为原文 I am running a 24 hr. test with a temperture data aquisition system. During this time the 3458A is reading ohmf on approx. 300 multiplexed channels. I would like to know if I can setup the 3458A to record into memory the internal temperture of the 3458A during the 24 hr period. I want to verify it has chaged more than ±1° during my testing time so I can keep my 24 hr accuracy. And if so will this interupt the operation of the ohmf. |
像Ulf提到的那样,可以从前面板或使用TEMP远程查询3458A内部温度?
命令。 如果从前面板查询,则没有内部存储此值的方法。 或者,在开始测试之前执行ACAL(例如ACAL DCV,ACAL OHMS,ACAL AC,ACAL ALL)会在执行校准时在内部存储3458A的内部温度。 可以使用以下命令和校准常数ID来读取此温度:CAL? 175 - acal dcv temperatureCAL? 176 - acal ohm temperature CAL? 177 - acal acv temperature在测试完成后执行ACAL将在测试期结束时提供内部温度。 以上来自于谷歌翻译 以下为原文 Like Ulf mentioned the 3458A internal temperature can be queried from the front panel or remotely using the TEMP? command. There is no method for storing this value internally if queried from the front panel. Alternatively, performing an ACAL (e.g. ACAL DCV, ACAL OHMS, ACAL AC, ACAL ALL) prior to starting your tests does store the internal temperature of the 3458A internally at the time the calibration is performed. This temperature can be read using the following command and calibration constant id’s: CAL? 175 – acal dcv temperature CAL? 176 – acal ohm temperature CAL? 177 – acal acv temperature Performing an ACAL after the tests complete will provide the internal temperature at the end of the test period. |
1297 浏览 0 评论
2378 浏览 1 评论
2199 浏览 1 评论
2068 浏览 5 评论
2955 浏览 3 评论
1140浏览 1评论
760浏览 0评论
950浏览 0评论
1298浏览 0评论
GMT+8, 2024-12-28 23:46 , Processed in 1.436611 second(s), Total 75, Slave 60 queries .
