1.当操作系统被调用时,操作系统会做什么?
2.如果我想通过FIFO把数据传输到外围设备,如果操作系统将参加?哪个例子介绍这个函数? 以上来自于百度翻译 以下为原文 1.when the os is invoked , what will the os do? 2.when I want to transfer date to peripheral by FIFO ,if the os will take part in ? which example introduce this function? |
你好,
请找到你的问题的答案: 1.当操作系统被调用时,操作系统会做什么? RTOS内核从主程序()中调用。这是一个不返回的调用,并设置thyx内核。在RTOS初始化结束时,创建所有驱动线程(DMA、GPIFIIIN端口、另一个串行接口等)。这些驱动线程是FX3库的一部分。 2.如果我想通过FIFO把数据传输到外围设备,如果操作系统将参加?哪个例子介绍这个函数? 如果您有兴趣将一些外围设备(FPGA或图像传感器)连接到FX3的GPIFII,请参阅SLaveFIFConcect和USBVideoClass示例。 下面的应用笔记也将有助于开始: AN6974-用EZ-USB®FX3从FIFO接口设计 AN7799-在USB视频类(UVC)框架中将图像传感器连接到EZ-USB®FX3域 谢谢, Sai Krishna。 以上来自于百度翻译 以下为原文 Hi, Please find the answers to your question inline: 1.when the os is invoked , what will the os do? The RTOS kernel is invoked next from the main(). This is a non-returning call and sets up the ThreadX kernel. At the end of the RTOS initialization, all the driver threads (one for DMA, GPIF II port, another serial interfaces etc..) are created. These driver threads are part of FX3 library. 2.when I want to transfer date to peripheral by FIFO ,if the os will take part in ? which example introduce this function? If you are interested to connect some peripheral (FPGA or an image sensor) to GPIF II of FX3 then please refer to slavefifosync and USBVideoClass examples. Also the following application notes will be helpful to get started: AN65974 - Designing with the EZ-USB® FX3 Slave FIFO Interface AN75779 - Interfacing an Image Sensor to EZ-USB® FX3™ in a USB video class (UVC) Framework Thanks, Sai Krishna. |
763个成员聚集在这个小组
加入小组2198 浏览 1 评论
1943 浏览 1 评论
3769 浏览 1 评论
1868 浏览 6 评论
1609 浏览 1 评论
1250浏览 2评论
682浏览 2评论
518浏览 2评论
494浏览 2评论
1368浏览 2评论
GMT+8, 2025-4-16 07:02 , Processed in 1.092737 second(s), Total 77, Slave 61 queries .
