嗨,我的一位朋友正在为FPGA套件上的防火墙实施项目,但他的FPGA套件Spatran 3E入门套件只有一个以太网端口(RJ-45)端口。
他需要两个端口来测试他的防火墙。 是否有任何接口可以在Spatran 3E上添加额外的以太网端口 谢谢 以上来自于谷歌翻译 以下为原文 Hi my one of the friends is doing project for implementation of firewall on FPGA kit but his FPGA kit Spatran 3E starter kit is having only one ethernet port(RJ-45) port. He require two ports to test his firewall. Is there any interface for putting additional ethernet port on Spatran 3E Thanks |
还记得Digilent的附加卡插入入门套件板吗?
您正在考虑使用一个连接7段LED显示屏。 您的朋友可以使用其中一个连接10BT或100BT以太网PHY。 您的朋友需要以太网PHY的硬件知识,MII接口以及如何向FPGA添加第二个MAC + MII接口。 - 鲍勃埃尔金德 签名:新手的自述文件在这里:http://forums.xilinx.com/t5/New-Users-Forum/README-first-Help-for-new-users/td-p/219369总结:1。 阅读手册或用户指南。 你读过手册了吗? 你能找到手册吗?2。 搜索论坛(并搜索网页)以寻找类似的主题。 不要在多个论坛上发布相同的问题。 不要在别人的主题上发布新主题或问题,开始新的主题!5。 学生:复制代码与学习设计不同.6“它不起作用”不是一个可以回答的问题。 提供有用的详细信息(请与网页,数据表链接).7。 您的代码中的评论不需要支付额外费用。 我没有支付论坛帖子的费用。 如果我写一篇好文章,那么我一无所获。 以上来自于谷歌翻译 以下为原文 Remember the add-on cards from Digilent which plug into the Starter Kit board? You were thinking of using one to wire up a 7-segment LED display. Your friend could use one of those to wire up a 10BT or 100BT ethernet PHY. Your friend would need hardware knowledge of ethernet PHYs, the MII interface, and how to add a second MAC plus MII interface to the FPGA. - Bob Elkind SIGNATURE: README for newbies is here: http://forums.xilinx.com/t5/New-Users-Forum/README-first-Help-for-new-users/td-p/219369 Summary: 1. Read the manual or user guide. Have you read the manual? Can you find the manual? 2. Search the forums (and search the web) for similar topics. 3. Do not post the same question on multiple forums. 4. Do not post a new topic or question on someone else's thread, start a new thread! 5. Students: Copying code is not the same as learning to design. 6 "It does not work" is not a question which can be answered. Provide useful details (with webpage, datasheet links, please). 7. You are not charged extra fees for comments in your code. 8. I am not paid for forum posts. If I write a good post, then I have been good for nothing. |
2309 浏览 7 评论
2722 浏览 4 评论
2204 浏览 9 评论
3283 浏览 0 评论
2356 浏览 15 评论
636浏览 1评论
1688浏览 1评论
447浏览 1评论
205浏览 1评论
654浏览 0评论
GMT+8, 2024-9-23 07:31 , Processed in 1.026022 second(s), Total 48, Slave 42 queries .
