您好,如果我想使用SPC5 Connect通过CAN对MCU进行编程,我需要在SPC5 Connect和MCU之间建立什么样的连接?我目前使用的MCU是SPC560B64L7。
以上来自于谷歌翻译 以下为原文 Hello, if i wanted to program the MCU using SPC5 Connect via CAN, what kind of connection did I need to make between SPC5 Connect and the MCU? The MCU I currently using is SPC560B64L7. |
4个回答
我正在使用的当前IC有CAN收发器接口,唯一可用的FlexCAN是FlexCAN 4,SPC-5 Connect是绑定到特定的FlexCAN还是可以连接到任何可用的FlexCAN?
以上来自于谷歌翻译 以下为原文 The current IC that I'm using has CAN transceiver interface and the only FlexCAN available is FlexCAN 4, is SPC-5 Connect tied down to a specific FlexCAN or can it be connected to any FlexCAN that is available? |
你好黄,
不,它是FlexCAN0 最好的祝福 二万 以上来自于谷歌翻译 以下为原文 Hello Wong , No , it is FlexCAN0 Best regards Erwan |
你好,Erwan,
谢谢回复。如果我想通过CAN对我的MCU进行编程,那么连接只是从SPC5-CONNECT到CAN0TX的CANC_RX和CANC_TX以及来自MCU的CAN0RX,是不是? 问候 皇 以上来自于谷歌翻译 以下为原文 Hello Erwan, Thanks for the reply. If i want to program my MCU via CAN, the connections are only CANC_RX and CANC_TX from SPC5-CONNECT to CAN0TX and CAN0RX from MCU, is it right? Regards Wong |
你好,Erwan,
对不起,这可能是因为我持怀疑态度,因为仅仅通过连接CAN RX和TX来编程MCU就太好了。如果我做出以下任何错误的假设,请纠正我。 SPC5-Connect在P3连接器上有CAN接口,我只需将SPC5-Connect的引脚21(CAN-H)和引脚22(CAN-L)连接到我的MCU(SPC560B64L7)FlexCAN0。忽略P3连接器中的所有其他引脚,例如SIN和SCK。感谢您的耐心和迄今为止提供的所有帮助。 问候 皇 以上来自于谷歌翻译 以下为原文 Hello Erwan, Sorry this may come out as me being skeptical, because programming a MCU just by connecting CAN RX and TX is just too good to be true. Please correct me if I make any of the assumptions below wrong. The SPC5-Connect has CAN interface at the P3 connector, I will just have to connect pin 21 (CAN-H) and pin 22 (CAN-L) of the SPC5-Connect to my MCU's (SPC560B64L7) FlexCAN0 only. Ignoring all the other pins from the P3 connector, such as SIN and SCK. Thank you for your patience and all the help provided thus far. Regards Wong |
2418 浏览 1 评论
3134 浏览 1 评论
1704 浏览 1 评论
3517 浏览 6 评论
5875 浏览 21 评论
861浏览 4评论
1236浏览 4评论
在Linux上安装Atollic TRUEStudio的步骤有哪些呢?
505浏览 3评论
使用DMA激活某些外设会以导致外设无法工作的方式生成代码是怎么回事
1218浏览 3评论
1273浏览 3评论
GMT+8, 2024-9-21 20:34 , Processed in 0.993359 second(s), Total 49, Slave 44 queries .
