这是关于使用PXA的多载波GSM测量。
在SWT / EVM菜单中,注意到“Carrier BPF Auto,Single and Multi”选项。 你能解释一下吗? 注意到在启用此载波BPF的情况下,多载波SWT测量得到了很大改进。 例如,具有7 MHz载波间隔的6C配置,GSMK SWT @ 1200 KJz显示出大约6 dB的改善! Wnat知道这个选项到底发生了什么? 以上来自于谷歌翻译 以下为原文 This is regarding multi-carrier GSM measurement using PXA. In the SWT/EVM menu, have noticed an option “Carrier BPF Auto, Single and Multi”. Could you please explain this?. Noticed big improvement in muti-carrier SWT measurement with this carrier BPF enabled. For example 6C configuration with 7 MHz carrier spacing, GSMK SWT @1200 KJz showed an improvement of around 6 dB!! Wnat to know what is really happeneing with this option ? |
嗨 - 您可以通过查看N9071A用户和程序员指南的第1175页了解Carrier BPF,Multi和Single:http://cp.literature.agilent.com/litweb/pdf/N9071-90015.pdf或者,
仪器在Multi Carrier菜单下,显示“Carrier BPF”软键。 按Help,然后按下软键“Carrier BPF”。 这将从用户指南中提取信息。 这解释了当存在除感兴趣信号之外的载波时您可能想要使用多载波滤波器的原因。 打开此滤波器可以部分或完全拒绝不需要的载波。 我没有关于“多个”过滤器的实际过滤器BW的详细信息。 问候 - 以上来自于谷歌翻译 以下为原文 Hi - You can learn about the Carrier BPF, Multi and Single by looking at page 1175 of the N9071A User’s and Programmer’s Guide: http://cp.literature.agilent.com/litweb/pdf/N9071-90015.pdf Or, on the instrument, under the Multi Carrier menu, where the “ Carrier BPF” softkey is displayed. Press Help, then the “ Carrier BPF” softkey. This will pull up the information from the user’s guide. This explains why you might want to use the multi carrier filter when there are carriers other than the signal of interest present. Turning on this filter allows partial or full rejection of the unwanted carriers. I do not have the particulars on the actual filter BW of “Multiple” filter. Regards - |
1038 浏览 0 评论
2282 浏览 1 评论
2068 浏览 1 评论
1942 浏览 5 评论
2811 浏览 3 评论
805浏览 1评论
590浏览 0评论
686浏览 0评论
2473浏览 0评论
1526浏览 0评论
GMT+8, 2024-9-22 05:35 , Processed in 1.105799 second(s), Total 48, Slave 42 queries .
