你好。我的大问题是cpscon,这取决于温度。天气凉爽时敏感度低,天气暖爽时敏感度太高。为什么?我用的是内部振荡器,但没有任何变化!!!!!!!为什么?我该怎么办????
以上来自于百度翻译 以下为原文 hi. my big problem is cpscon that is dependon temperature.when weather be cool sensitivines be low and when weather be wARM sensitivines be too high. why?? I used from internall oscillator but don't any change!!!!!why?? how can I do??? |
19个回答
这儿有人能帮我吗?为什么?这意味着PIC依赖于TEMOREST??
以上来自于百度翻译 以下为原文 is here any one to help me/?? why?? means that pic is depend on temerture?? |
嗨,有1200种不同的图片……你用哪一种?你的系统有什么问题?当做
以上来自于百度翻译 以下为原文 Hi, there are 1200 differents PICs....Which one do you use ? what is the issue in your system ? Regards |
这是众多线程中的一个:HTTP://www. McCHIP.COM/FUMMS/M963633.ASPX
以上来自于百度翻译 以下为原文 this was one of those many threads: http://www.microchip.com/forums/m963633.aspx |
我使用PIC16F1823,当我的系统是温暖或凉爽时,CSCSon的灵敏度会改变!!!!!!!我不能有一个稳定的系统,因为每次天气变化都会改变灵敏度。
以上来自于百度翻译 以下为原文 I use from pic16f1823 .when my system be warm or cool the sensitiviness of cpscon be change !!!!! and I can't have a stable system because sensitivity change every time if change the weather |
在我的触摸键盘上,我加了一些检查,如果读数变化很快,这将被认为是漂移,因此基线将移动,使δ保持零。读数的快速变化意味着按键,因此不会影响基线。这确实有点帮助。
以上来自于百度翻译 以下为原文 In my touch keyboard, I added some check that if the readout is changing quickly, this will be considered a drift and so the baseline will move so that delta stays zer0. A quick change in readout means a keypress and hence won't affect the baseline. this does help a bit. |
嗨,如果这是一个触摸应用,一般使用的内部上限的S/H。这个上限值随温度变化很大。需要连续采样来计算平均值,当有人触摸键时可以看到变化。
以上来自于百度翻译 以下为原文 Hi, If this is a touch application, generally the internal cap of the S/H is used. this cap value changes quite a lot according to temperature. It is necessary to continuously sample to compute the average value to that when someone touch a key the variation can be seen. Regards |
我可以连续取样吗?如果手指在触摸,我得到样品错误精度。你能帮我一个简单的问候吗?
以上来自于百度翻译 以下为原文 Hi how can I get continuously sample?? if finger was on the touch and I get the sample mistake accur . can you help me more with a simple. Regards |
可以使用内部温度传感器来确定芯片温度。您可以使用它来确定灵敏度应该是什么。
以上来自于百度翻译 以下为原文 You could use the internal temperature sensor to determine the chips temperature. You can use that to determine what the sensitivity should be |
看在上帝的份上,当你问下一个肯定是“如何阅读传感器”的问题时,不要开始一个新的话题,只要继续这个话题就行了。否则,我们不得不再次问同样的问题。
以上来自于百度翻译 以下为原文 and for god's sake, when you ask your next question, which is sure to be "how to read that sensor", don't start a new topic about it, just continue in this one. Otherwise we have to ask all the same questions again. |
你能帮助我连续取样吗?因为如果我在传感器上靠近手指很慢,传感器就无法感知。因为思考就是噪音。你能给我举个例子或者给出一个算法吗????
以上来自于百度翻译 以下为原文 can you help me about continuously sample?? because if I near the finger very slowly on sensor, sensor can't sensing. because think is noise. can you give me an example or give an algorithm??? |
我只有4个LED的4个频道。但我的问题是温度,因为我用的是固定基数。现在我使用的是可变基数,我的问题是快速检测传感器。传感器应触摸手指并关闭手指附近返回。但是,当我触摸传感器传感器连续工作。我想要一个好的流程图,但我现在找不到。你能帮我写一下流程图吗?谢谢
以上来自于百度翻译 以下为原文 I have just 4 channel for 4 led. but my problem was temperture because I used from fix base number. now I use from variable base number and my problem is fast detect sensor. sensor should touch finger and turn off to return near the finger. but when I touch the sensor sensor work continuously. I want a good fluchart but I don't found now. can you more help me about write flowchart? Thanks |
喜mohammad mahdiFor帽触摸应用,请考虑使用CVD方法通过ADC,而不是CPS模块。CVD触摸比通过CPS模块进行触摸更健壮和可重复。下面是一个示例,它将帮助您设置它。http://Microchip…WikiTo.UC:低成本MouTug工具包
以上来自于百度翻译 以下为原文 Hi mohammad mahdi For cap touch applications please consider using the CVD method via the ADC rather than CPS module. CVD touch is much more robust and repeatable than doing touch via the CPS module. Below is an example which will walk you through setting it up. http://microchip.wikidot....uch:lowcost-mtouch-kit |
5275 浏览 9 评论
2048 浏览 8 评论
1962 浏览 10 评论
3225 浏览 3 评论
2272 浏览 5 评论
807浏览 1评论
702浏览 1评论
636浏览 1评论
696浏览 0评论
592浏览 0评论
GMT+8, 2025-1-6 13:27 , Processed in 1.502669 second(s), Total 116, Slave 99 queries .
