我有一个项目在Windows 10 /MPLAB X 3.40上工作,然后升级到3.45。当我设置断点时,IDE崩溃,没有警告或错误。最终发现论坛帖子下载了一个新的UBAccess链接。这解决了崩溃,但我的以太网链路不工作(它通过USB转换器)。最后提交了一张到Microchip的机票。一天之内他们就解决了这个问题。在试图找到错误时,我移动到一个MAC,并在MAC上安装了所有相同的组件。威廉希尔官方网站
支持人员带领我完成了以太网启动器工具包II(我的硬件)的示例项目。当然,它工作得很好。然后我去了PC版本,它没有工作。我完全清除了MPLAX X从PC和重新安装V3.50。尝试重新编译并重新加载在v3.40上运行的项目,但是(等待),它在v3.50上没有工作!!!!IDE没有识别启动器套件,因此无法连接(连接失败消息)。所以我猜3.50比3.45要好,但是用新的dll比3.45差。幸运的是我可以回到我的MAC继续。问:对于MPLAB X的各种升级是否执行了SQA,或者这些MPLAB X版本都是“beta”,用户是测试人员吗?
以上来自于百度翻译 以下为原文 I had a project working on Windows 10/MPLAB X 3.40, then upgraded to 3.45. When I set a breakpoint, the IDE crashed with no warning or errors. Eventually found the forum post to download a new USBAccessLink.dll. That solved the crashing, but then my Ethernet link did not work (it goes through a USB converter). Finally submitted a ticket to Microchip. Within a day they solved the problem (sort of). In trying to find the error, I moved to a MAC and installed all the same components on the MAC. The tech support guy walked me through the example project for the Ethernet Starter Kit II (my hardware). Of course, it worked perfectly. I then went to the PC version and it did not work. I completely cleaned out MPLAB X from the PC and re-installed v3.50. Tried to recompile and reload the project that worked on v3.40, and, (wait for it), it did not work on v3.50!!! The IDE did not recognize the Starter Kit so it could not connect (Connection failed message). So I guess 3.50 is better than 3.45 but worse than 3.45 with new dll. Luckily I can go back to my MAC to continue. Q: Is there any SQA performed on the various upgrades to MPLAB X or are these MPLAB X versions all "beta" and the users are the testers? |
6个回答
或多或少在这里XP 32位,4GB…只是调试器变慢了
以上来自于百度翻译 以下为原文 More or less ok in here on XP 32bits, 4GB... Just debugger got slower |
嗨,根据我的经验,将带有PKOB调试器(Pickit On.)的启动器工具包从一个MPLAB X版本移动到另一个版本并不总是容易的。有时它们没有被正确地识别,固件没有得到更新……
以上来自于百度翻译 以下为原文 Hi, From my experience it is not always easy to move a starter kit with PKOB debugger (Pickit On Board) from one MPLAB X version to another one. Sometimes they are not recognized properly and the firmware does not get updated... Regards |
这比我想象的更糟。V3.50在PC或MAC上不认识我的以太网启动器套件II。所以我从我的Mac卸载V3.50,尝试V3.45。现在它没有工作(即连接失败)的初学者工具包。我知道V3.45在我安装3.50之前工作,所以我安装了所有东西(两个版本)并重新安装了3.45个。一切都如愿以偿。我注意到MPLABX目录中有两个子目录,MPLABCOMM和MPLABCOMP-1.0。我认为问题在MPLABCOMM,V3.22。我没有时间继续调试MPLAB X,所以我会提交一张支持票。只是觉得这篇文章可能会帮助其他人避免我刚刚经历的挫折周……
以上来自于百度翻译 以下为原文 It is worse than I thought. v3.50 does not recognize my Ethernet Starter Kit II on either PC or MAC. So I uninstalled v3.50 from my MAC and tried v3.45. Now it did not work (i.e. Connection Failed) to the starter kit. I know that v3.45 worked before I installed 3.50, so I installed everything (both versions) and reinstalled 3.45. Everything worked as expected. Arrg... I did notice that there were two subdirectories in the MPLABX directory, mplabcomm and mplabcomm-1.0. I think the problem is in mplabcomm, v3.22. I don't have time to keep debugging MPLAB X, so I will submit a support ticket. Just thought this post might help others avoid the week of frustration I just went through... |
3.50的作品与真正的冰,但真的很慢,单步后退到3.45对我来说…
以上来自于百度翻译 以下为原文 3.50 works with real ice, but REALLY slow to single step back to 3.45 for me..... |
我在3.50和ICD3上遇到了问题,上周五我打开了同一个项目,没有修改任何东西,只能在编程时构建MPLAB IDE。如果我转到“Debug>Run Debugger/Programmer.Test”,它就会卡在工具窗口(您可以看到附带的PNG)。
以上来自于百度翻译 以下为原文 I'm having problems with 3.50 and my ICD3, I've opened same project I was working last Friday and with out modifying nothing I can build but MPLAB IDE freezes when programming. If I go to "Debug> Run Debugger/Programmer Self Test" it gets stuck at the tool window (you can see the attached PNG). Attached Image(s) |
5317 浏览 9 评论
2072 浏览 8 评论
1977 浏览 10 评论
3248 浏览 3 评论
2285 浏览 5 评论
830浏览 1评论
723浏览 1评论
669浏览 1评论
722浏览 0评论
618浏览 0评论
GMT+8, 2025-1-31 19:58 , Processed in 1.006981 second(s), Total 57, Slave 51 queries .
