我有一个FX2LP设计与一组描述符来创建一个USB音频设备。该设备实现了扬声器,所以我有一个USB流输入和扬声器输出。该设备被Windows识别为USB音频设备。然而,当我打开媒体播放器和播放MP3,我没有得到任何数据出来的FX2LP。我应该提到的是,FX2连接到FPGA。我有一个程序监视进入FPGA的数据,但什么也没有发生。有人有什么想法吗?如果有人看到任何问题,我就附上了文件。
谢谢 乔恩 以上来自于百度翻译 以下为原文 I have a FX2LP design with a set of descriptors to create a USB audio device. The device implements a speaker, so I have a USB streaming input and a speaker output. The device is recognised by Windows as a USB audio device. However when I open media player and play an mp3 I dont get any data coming out of the FX2LP. I should mention that the FX2 is connected to an FPGA. I have a program monitoring the data coming into the FPGA, but nothing happens. Does anyone have any thoughts? I have attached the file if anyone can see any problems. Thanks Jon |
6个回答
对不起,附件。我有更多的信息。如果我使用一些软件来查看Windows中的USB流量,我可以看到媒体播放器试图发送一个同步传输。我有以下错误。有没有人知道什么会导致这个错误。我只能相信描述符一定有问题。
URB-ISOCH转移失败 设备对象8C1B3B8H 驱动对象HHDUSSBH32 URB功能 URB状态 端点02h 2出,等时 数据包数10 以上来自于百度翻译 以下为原文 Sorry about the attachement. I have some more info. If I use some software to look at the USB traffic in Windows, I can see that media player tries to send an isochronous transfer. I get the following error. Does anyone know what would cause this error. I can only believe that the descriptor must have a problem. URB Isoch Transfer failed Device Object 87C1B3B8h Driver Object hhdu***h32 URB Function URB_FUNCTION_ISOCH_TRANSFER URB Status USBD_STATUS_INVALID_PARAMETER Endpoint 02h 2 Out, Isochronous Number of Packets 10 |
它仍然没有附加文件。我不断添加它,但它没有出现在线程中。
以上来自于百度翻译 以下为原文 It still hasnt attached the file. I keep adding it but it doesnt appear in the thread. |
我会尝试重命名文件,看看是否有帮助。
DSCR 2 K 以上来自于百度翻译 以下为原文 I will try renaming the file to see if that helps.
问题解决了。当我使用高速USB时,BStand的值必须设置为4,以给出1ms。
2 ^ 4-1=8 8×125US=1毫秒 以上来自于百度翻译 以下为原文 Problem solved. As I am using high speed USB the value of bInterval has to be set to 4 to give 1ms. 2 ^ 4-1 = 8 8 x 125us = 1 ms |
757个成员聚集在这个小组
加入小组2137 浏览 1 评论
1877 浏览 1 评论
3700 浏览 1 评论
1815 浏览 6 评论
1561 浏览 1 评论
756浏览 2评论
509浏览 2评论
470浏览 2评论
422浏览 2评论
1113浏览 2评论
GMT+8, 2025-2-2 19:03 , Processed in 0.894491 second(s), Total 55, Slave 49 queries .
