大家好,我正在尝试使用33210A信号发生器来确定PCB布局不佳的ADC的SNR损耗。
来自数据表的ADC的SNR为85dB,我的测量结果为70dB。 我需要确定ADC侧的15dB差异以及mych如何来自发电机本身。 为了做到这一点,我显然需要知道生成信号的噪声是什么。 我无法使用任何设备来测量发电机的输出信号噪声或SNR。 有没有办法从发电机数据表的信息中确定? 我正在使用的信号是1.4V的100Hz正弦波,我的最终测量带宽是6kHz。 以上来自于谷歌翻译 以下为原文 Hello All, I'm trying to use the 33210A signal generator to determine SNR loss of an ADC with poor PCB layout. The ADC's SNR from datasheet is 85dB and my measurement shows 70dB. I need to determine how much from that 15dB difference is on the ADC side and how mych comes from the generator itself. In order to do that I obviously need to know what's the noise of the generated signal. I don't have access to any equipment to measure the generator's output signal noise or SNR. Is there any way to determine that from the information from the generator's datasheet? Signal that I'm using is 1.4V of 100Hz sinewave and my final measurement bandwidth is 6kHz. |
感谢您的回答。
在我看来,你的方法是正确的,但它假设DC-6kHz频段的噪声频谱是平坦的,并且当你在发生器上调高放大器时噪声根本没有放大。 我不确定这两件事情,所以我无法自信地使用你的测量噪声值和SNR。 但是,这肯定让我对价值有所了解。 以上来自于谷歌翻译 以下为原文 Thanks for your answer. Your approach seems to me to be correct, but it assumes that noise spectrum is flat in DC-6kHz band and that the noise is not amplified at all when you turn the ampliture up on the generator. I'm not sure about those two things so I can't use your measured noise value and SNR with confidence. However, that definitely gives me an idea of the value. |
1349 浏览 0 评论
2405 浏览 1 评论
2234 浏览 1 评论
2088 浏览 5 评论
2981 浏览 3 评论
1311浏览 1评论
793浏览 0评论
1098浏览 0评论
1349浏览 0评论
GMT+8, 2025-1-31 17:53 , Processed in 1.144372 second(s), Total 44, Slave 39 queries .
