在试图在电源/电机控制应用的外围设备上达到速度时,我看到有可编程开关模式控制器(PSMC)和互补波形发生器/互补输出发生器模块。是否有文件比较和对比这些外设?PSMC是CWG/COG特性的超集吗?或者一个人有效地替代了另一个人的角色?你什么时候选一个和另一个?或者有一个微控制器既有PSMC又有CWG/COG外围设备?我知道我有一些阅读要做,但我想也许有人能告诉我两个外围设备之间的区别,以此来加速我的进度。谢谢,格雷格。
以上来自于百度翻译 以下为原文 In trying to come up to speed on the peripherals for power supply/motor control applications, I see there is the Programmable Switch Mode Controller (PSMC), and the Complementary Waveform Generator/Complementary Output Generator modules. Is there a document comparing and contrasting these peripherals? Is the PSMC a superset of the features of the CWG/COG? Or does one effectively subsume the role of the other? When would you pick one vs. the other? Or is there a microcontroller that has both the PSMC and the CWG/COG peripherals? I know I've got some reading to do, but I thought someone might be able to speed things along for me by giving be a gist of the difference between the two peripherals. Thanks, Greg |
另外,在PSMC页面的“Video”选项卡下(http://imgur.com/a/AzdkF),我看到一条关于需要升级我的Flash插件的消息。我不认为这是准确的,因为微芯片.com上的所有其他视频似乎都正常工作,我在这个页面上尝试过几种不同的浏览器。有没有人知道有没有一个描述PSMC的视频?
以上来自于百度翻译 以下为原文 Also, under the "Video" tab of the PSMC page (http://imgur.com/a/AzdkF), I see a message about needing to upgrade my Flash plugin. I don't think this is accurate, since all the other videos at microchip.com appear to work, and I've tried several different browsers on this page. Does anyone know if there is a video describing the PSMC? |
5585 浏览 9 评论
2228 浏览 8 评论
2115 浏览 10 评论
3399 浏览 3 评论
2433 浏览 5 评论
1070浏览 1评论
899浏览 1评论
919浏览 1评论
947浏览 0评论
我是Microchip 的代理商,有PIC16F1829T-I/SS 威廉希尔官方网站 问题可以咨询我,微信:A-chip-Ti
644浏览 0评论
GMT+8, 2025-7-19 09:20 , Processed in 1.229957 second(s), Total 45, Slave 39 queries .
