亲爱的大家,有没有办法使用安装在我笔记本电脑上的用于MPLAB的C8和C16编译器来生成用于编译和链接在Windows笔记本电脑上执行的二进制文件的通用C代码,而不是为微芯片控制器生成二进制文件?与安装用于构建Windowscode.sMichael的附加C编译器相比,我更喜欢在两个任务中使用相同的编译器
以上来自于百度翻译 以下为原文 Dear all, Is there a way to use the C8 and C16 compilers installed on my laptop for MPLAB to generate general C code for compiling and linking binaries executing on my Windows laptop rather than generate binaries for the microchip controllers? I would prefere to use the same compiler for both tasks over installing an additional C compiler for building Windows code thanks Michael |
4个回答
不!…或者,如果你想要第二种观点…:)
以上来自于百度翻译 以下为原文 No! ... or, if you'd like a second opinion... :) |
您好,XC16和XC32编译器是从GCC的GNU编译器集合中开发的。您可以为Windows x86或IA64安装GCC C编译器,它与命令行选项、语用和属性非常相似,只要它与不同的处理器有关。https://en.wikipedia.org/wiki/GNU_Compiler。收藏没有C8编译器,8位PIC设备的高科技编译器被改名为XC8。
以上来自于百度翻译 以下为原文 Hi, XC16 and XC32 compilers are developed from GNU Compiler Collection, GCC. You may install GCC C compiler for Windows x86 or IA64, it is very much the same, command line options, pragmas and attributes, as far as it is relevant for the different processors. https://en.wikipedia.org/wiki/GNU_Compiler_Collection There is no C8 compiler, the Hi-Tech compiler for 8 bit PIC devices was renamed to XC8. Regards, Mysil |
您还可以下载微软免费C Express编译器。
以上来自于百度翻译 以下为原文 You could also download the Microsoft free C express compiler. |
5064 浏览 9 评论
1945 浏览 8 评论
1879 浏览 10 评论
3104 浏览 3 评论
2175 浏览 5 评论
615浏览 1评论
484浏览 1评论
344浏览 1评论
515浏览 0评论
422浏览 0评论
GMT+8, 2024-9-20 18:44 , Processed in 1.080780 second(s), Total 49, Slave 44 queries .
