扫一扫,分享给好友
如我所知,ICE-4000与PD V.4.3兼容,不兼容V.4.4和更高版本。所以,我的问题是:如果我尝试用PD V.5.3将十六进制文件加载到ICE-4000中,会发生什么情况,使用PD V.4.3。会奏效吗?
以上来自于百度翻译 以下为原文 As I know ICE-4000 is compatible with PD v.4.3 and not compatible with v.4.4 and later. So my question: what happen if I try to load hex-file which was worked out by PD v.5.3 into ICE-4000, using the PD v.4.3. Will it worked? |
你使用哪个设备?参见KB文章关于ICE4000支持的PSoC设备
HTTP://www. CyPress?COM/?ID=4和;RID=45620 您可能需要安装PSoC程序员V2.33。参见下面的KB文章 HTTP://www. CyPress?COM/?ID=4和;RID=34495 不可能在PD4.2中用其他项目生成的HEX文件进行编程;在这种情况下,PD5.3项目。 以上来自于百度翻译 以下为原文 Which device are you using? See following KB article on PSoC devices supported by ICE4000 - http://www.cypress.com/?id=4&rID=45620 You may have to install PSoC programmer v2.33. See below KB article - http://www.cypress.com/?id=4&rID=34495 It is not possible to program in PD4.2 with a hex file generated by some other project; in this case, PD5.3 project. |
我也这样认为。HEX文件格式不应更改。但我不是100%肯定。
然而,这里的主要问题不是设计者的版本,而是程序员软件版本。你应该有V2.33来和ICE4000对话。 以上来自于百度翻译 以下为原文 I also think so. Hex file format should not change. But I am not 100% sure. However, the main issue here is not the designer version but the programmer software version.You should have v2.33 to talk to ICE4000. |
760个成员聚集在这个小组
加入小组2151 浏览 1 评论
1897 浏览 1 评论
3718 浏览 1 评论
1829 浏览 6 评论
1574 浏览 1 评论
778浏览 2评论
536浏览 2评论
482浏览 2评论
443浏览 2评论
1139浏览 2评论
GMT+8, 2025-2-25 00:19 , Processed in 0.878364 second(s), Total 77, Slave 61 queries .
