我们已经注意到在低温下启动FX3的一些问题。我们有一个产品上使用CysB3014-BZXI,它使用了一个从24FC256I/SN正确加载的I2C引导加载程序。注TTAT板上的所有其他部分也额定为全工业温度范围。这个引导装载器查看附加的SPIFFlash(微米N25Q128A11B1240E)以获得更大的启动映像。
. 在室温下,这个过程运行良好。SPIGION被加载并引导FX3。设备正确枚举。 . 在低温度(接近0C)时,引导加载程序无法从SPI中检索图像。失败后,它被设计为枚举自己的设备,并且可以接受非常有限的指令。 . 到目前为止,这些都是现场故障,目前还没有在实验室进行评估。我们没有太多的信息,但想看看是否有人经历过这一点。 以上来自于百度翻译 以下为原文 We have noticed some issues with booting the FX3 at low temperatures. We have the CYUSB3014-BZXI on a product which uses an I2C bootloader that is loading correctly from a 24FC256-I/SN. Note thtat all other parts on the board are also rated for the full industrial temperature range. This bootloader looks to the attached SPI Flash (Micron N25Q128A11B1240E) for a larger boot image. . At room temperatures, this process has worked fine. The SPI image is loaded and boots the FX3. The device correctly enumerates. . At low temperatures (approaching 0C), the bootloader fails to retrieve the image from SPI. Upon failure, it is designed to enumerate as its own device and can accept very limited instructions. . These have been field failures so far and not evaluated in the lab just yet. We don't have too much information yet but wanted to see if anyone else had experienced this. |
嗨,卫国明,
谢谢你让我们知道这件事。 我很想知道是否有其他类似的问题。 请收集一个威廉希尔官方网站 支持案例,一旦你收集了所有与此问题有关的信息。如果这个问题存在,我们将做法农来理解到底出了什么问题。 当做, Sai Krishna。 以上来自于百度翻译 以下为原文 Hi Jake, Thanks for letting us know about this. I am interested to know if any other experienced a problem similar to this. Please create a tech support case once you have collected all the information related this problem. We will do FA on it to understand what is going wrong, if that problem exists. Regards, Sai Krishna. |
随着四个设备,这个问题现在已经确认所有四个AT -26C(-15F)。
以上来自于百度翻译 以下为原文 With four devices, this problem has now been confirmed on all four at -26C (-15F). |
756个成员聚集在这个小组
加入小组2129 浏览 1 评论
1871 浏览 1 评论
3687 浏览 1 评论
1806 浏览 6 评论
1552 浏览 1 评论
622浏览 2评论
460浏览 2评论
455浏览 2评论
408浏览 2评论
1099浏览 2评论
GMT+8, 2025-1-23 17:30 , Processed in 0.945918 second(s), Total 77, Slave 61 queries .
