我在用
STM8L051F3 为我的项目。我的项目使用10个LED,timer2和1个输入引脚。从1针输入后,我将在LED 1上通过1.系统由电池供电,因此运行时电流应该最小。不使用睡眠,停止如何以最低功率运行系统。请指导我完成这个。 以上来自于谷歌翻译 以下为原文 I am using STM8L051F3 for my project. My project uses 10 LEDs, Timer2 and 1 input Pin. After getting input from 1 pin i will on the LEDs 1 by 1. System powered with battery so run time current should be minimum. Without using sleep, Halt how can i run the system at lowest power. Please guide me through this. |
Okk谢谢,我有另一个查询,我有STM8L051F3,它没有LCD控制器。我正在寻找内置LCD控制器的低功耗,低成本控制器。 ST MCU查找器无助于找到哪个控制器内置LCD控制器,功耗低,成本低。我搜索了其中一些,但我需要你的意见和建议。
以上来自于谷歌翻译 以下为原文 Okk thanks, I have another query, I have STM8L051F3 and it has not LCD controller. I am looking for low power,low cost controller with LCD controller inside. ST MCU finder doesnt help to find which controller has LCD controller inside and low power and low cost. I searched some of them but i need your opinion and recommandation. |
2738 浏览 1 评论
3241 浏览 1 评论
1810 浏览 1 评论
3650 浏览 6 评论
6039 浏览 21 评论
1339浏览 4评论
201浏览 3评论
对H747I-DISCO写程序时将CN2的st-link复用为usart1,再次烧录时无法检测到stlink怎么解决?
353浏览 2评论
STM32G474RE芯片只是串口发个数据就发烫严重是怎么回事?
444浏览 2评论
STM32处理增量式编码器Z信号如何判断中断是正转的还是反向转的?
275浏览 2评论
GMT+8, 2024-12-25 10:37 , Processed in 1.205347 second(s), Total 45, Slave 40 queries .
