大家好。
最近我一直在编程E8257D合成器。 我正在尝试使用“freq:fix xghz”命令设置固定频率,使用“x”设置频率。 我收到“数据超出范围”错误。 该命令通常在以前工作,但现在不起作用。 几个月前修复了合成器,现在它有最新的固件(c.06.16)。 我们在2006年买了它,可能固件没有升级到今年。 可能是固件问题呢? 会建议返回以前的固件吗? 我正在使用与之前相同的设置(当它工作时),使用gpib-u***接口。 谢谢你的帮助。 以上来自于谷歌翻译 以下为原文 Hi all. Lately i have been programing the E8257D synthetizer. I'm trying to set a fixed frequency with the "freq:fix xghz" command, with "x" the frequency to set. I get a "data out of range" error. The command usually worked before, but now isn't working. The synthetizer was repaired a few months ago, and now it has the latest firmware(c.06.16). We bought it about 2006 and probably the firmware wasn't upgraded up to this year. Could be a firmware problem then? Would be recommended to return to previous firmware? I'm using the same setup as before (when it was working), witht gpib-u*** interface. Thanks for any help. |
嗨 - 我们尝试了命令,它工作正常。
输入的频率可能超出单位范围。 :FREQuency:FIXed支持所有模型[:SOURce]:FREQuency:FIXed | UP | DOWN [:SOURce]:FREQuency:FIXed? 此命令设置信号发生器输出频率,或增加或减少当前RF频率设置。 频率值。 UP通过第125页上的:FREQuency [:CW]:STEP [:INCRement]命令设置的值增加当前频率设置。前面板向上箭头键执行相同的功能。 DOWN通过第125页上的:FREQuency [:CW]:STEP [:INCRement]命令设置的值减小当前频率设置。前面板向下箭头键执行相同的功能。 要设置频率模式,请参见“:FREQuency:MODE”(第119页)。有关信号发生器频率和功率规格的列表,请参阅第153页上的“[:LEVel] [:IMMediate] [:AMPLitude]”。示例: FREQ:FIX 10GHZ前面的例子将信号发生器频率设置为10 GHz。 * RST http://cp.literature.agilent.com/litweb/pdf/E8251-90356.pdf问候 - 以上来自于谷歌翻译 以下为原文 Hi - We tried the command and it works fine. It is possible the entered frequency is exceeding the range on unit. :FREQuency:FIXed Supported All Models [:SOURce]:FREQuency:FIXed |UP|DOWN [:SOURce]:FREQuency:FIXed? This command sets the signal generator output frequency , or increments or decrements the current RF frequency setting. A frequency value. UP Increases the current frequency setting by the value set with the :FREQuency[:CW]:STEP[:INCRement] command found on page 125. The front panel up arrow key performs the same function. DOWN Decreases the current frequency setting by the value set with the :FREQuency[:CW]:STEP[:INCRement] command found on page 125. The front panel down arrow key performs the same function. To set the frequency mode, see “:FREQuency:MODE” on page 119. For a listing of signal generator frequency and power specifications, refer to “[:LEVel][:IMMediate][:AMPLitude]” on page 153. Example :FREQ:FIX 10GHZ The preceding example sets the signal generator frequency to 10 GHz. *RST http://cp.literature.agilent.com/litweb/pdf/E8251-90356.pdf Regards - |
1342 浏览 0 评论
2400 浏览 1 评论
2226 浏览 1 评论
2088 浏览 5 评论
2980 浏览 3 评论
1273浏览 1评论
788浏览 0评论
1065浏览 0评论
1342浏览 0评论
GMT+8, 2025-1-24 05:23 , Processed in 1.058076 second(s), Total 41, Slave 36 queries .
