我正在编写自己的代码用于我的Spartan6 FPGA的JTAG配置。
但是,我无法让它发挥作用。 出于调试目的,我想尝试读取配置寄存器(例如STAT,IDCODE),但也不能这样做。 这是我粗略的事件序列: 1)通过JTAG读出IDCODE,(这个工作) - >以TEST_LOGIC_RESET状态结束 2)发出JPROGRAM JTAG指令,这似乎有效,因为FPGA此时丢失了配置/停止驱动IO。 再次,转到TEST_LOGIC_RESET状态。 3)发出CFG_IN Jtag指令,然后移入SYNC字,然后将状态寄存器命令读入JTAG数据寄存器。 4)发出CFG_OUT JTAG指令,然后移出JTAG数据寄存器的16位。 以TEST_LOGIC_RESET状态结束。 但是,无论我尝试读取什么寄存器,移出的数据总是“0008”。 我猜我在创建命令时做错了什么。 请帮忙! 如果需要,我很乐意提供更多详细信息。 谢谢, 梅根 以上来自于谷歌翻译 以下为原文 I am writing my own code for JTAG configuration of my Spartan6 FPGA. However, I am not able to get it to work. For debugging purposes, I wanted to try to read the Configuration registers (eg STAT, IDCODE), but can not do that either. Here is my rough sequence of events: 1) Read out IDCODE through JTAG, (this works) -> end in TEST_LOGIC_RESET state 2) Issue JPROGRAM JTAG instruction, which seems to work because FPGA loses its configuration/stops driving IOs at this point. Again, go to TEST_LOGIC_RESET state. 3) Issue CFG_IN Jtag instruction, then shift in the SYNC word then read status register command into the JTAG data register. 4) Issue CFG_OUT JTAG instruction, then shift out 16 bits of the JTAG data register. End in TEST_LOGIC_RESET state. However, the shifted out data is always "0008", no matter what register I attempt to read from. I am guessing I am doing something wrong in creating my command, or something. Please help! I am happy to provide more details if requested. Thanks, Megan |
您应该在运行测试/空闲状态中结束转换,而不是在测试逻辑复位中。
以上来自于谷歌翻译 以下为原文 You should end your shifts in the Run Test/Idle state, not in Test Logic Reset. |
2487 浏览 7 评论
2865 浏览 4 评论
2324 浏览 9 评论
3415 浏览 0 评论
2506 浏览 15 评论
2316浏览 1评论
650浏览 1评论
515浏览 1评论
2063浏览 0评论
791浏览 0评论
GMT+8, 2025-2-13 01:00 , Processed in 2.398466 second(s), Total 75, Slave 59 queries .
