嗨,我已经构建并测试了从SD读取文件以重新刷新设备的演示引导加载器项目。下一步任务是构建要刷新的主应用程序。我是否需要将引导加载器库添加到和谐配置中的主应用程序,选择“构建和应用程序链接器脚本”,运行MHC,然后构建我的应用程序?或者我在引导加载程序中运行MHC来构建主应用程序使用的链接器脚本吗?可能已经解释过很多次了!但我还没找到它。
以上来自于百度翻译 以下为原文 Hi, I have built and tested the demo bootloader project which reads a file from SD to reflash the device. Next task is to build the main application to be flashed. Do I need to add the bootloader library to my main app within hARMony config, select "Build and Application Linker Script", run MHC, then build my app? Or do I run MHC within the bootloader app to build a linker script for the main app to use? Probably already been explained (many times!), but I haven't found it yet. Cheers Martin |
3个回答
您需要引导程序应用程序为主应用程序生成链接器脚本。它可以在和声帮助文件中解释。
以上来自于百度翻译 以下为原文 You need the linker script that the bootloader app generates for the main app. It may be explained in the harmony help file. |
嗯,那并没有太大的压力,一旦我意识到我必须要做什么:)BootLoader似乎工作得很好,从sd卡闪烁一个十六进制文件。
以上来自于百度翻译 以下为原文 well that wasn't too stressful, once I realised what I had to do :) BootLoader seems to be working well, flashing a hex file from from sd card. |
5283 浏览 9 评论
2055 浏览 8 评论
1968 浏览 10 评论
3231 浏览 3 评论
2276 浏览 5 评论
820浏览 1评论
709浏览 1评论
652浏览 1评论
710浏览 0评论
605浏览 0评论
GMT+8, 2025-1-12 02:47 , Processed in 1.156095 second(s), Total 81, Slave 65 queries .
