你好,
我需要帮助才能使用X-NUCLEO-CCA02M1和STEVAL-MKI155V3将X-CUBE-MEMSMIC的4麦克风架构扩展到6个麦克风。我附加了修改后的BSP驱动程序.c和.h文件。同样在audio_application.h我改变了号码。将麦克风设置为6.我试图为麦克风M5和M6配置SPI3。我看到SPI1和SPI3的slave选择是相同的,因为在这种情况下没有使用slave select,我知道这不应该是一个问题。你能不能让我知道我应该调查哪些部分代码才能让它适用于6个麦克风。我也试图增加PDM缓冲区但没有成功。我看到PDM数据在所有4个麦克风的范围内都可用,但是由于我的部分代码的变化,数据没有被记录。除了x_nucleo_cca02m1_audio_f4 BSP驱动程序之外,我应该考虑将其扩展到6个麦克风架构。 谢谢, 拉姆亚 以上来自于谷歌翻译 以下为原文 Hello, I need help with regard to extending the 4 microphone architecture of X-CUBE-MEMSMIC to 6 microphones using X-NUCLEO-CCA02M1 and STEVAL-MKI155V3. I have attached the modified BSP driver .c and .h files. Also in audio_application.h I have changed the no. of microphones to 6. I have tried to configure SPI3 for microphones M5 and M6. I see that slave select for both SPI1 and SPI3 are the same and since the slave select is not being used in this case, I know this shouldnt be a problem. Can you please let me know which all part of the code should I look into to get it working for 6 microphones. I have also tried to increase the PDM buffer but have not been successful. I see that PDM data is available on scope on all the 4 microphones but due to changes from my part of the code the data is not being recorded. Apart from the x_nucleo_cca02m1_audio_f4 BSP driver which part I should look into to extend the same to 6 microphone architecture. Thanks, Ramya |
en.X-CUBE-MEMSMIC1
我想将此添加到stm32cube但是说这个版本不适用于此stm32cube版本 STM32CubeExpansion_MEMSMIC1_V1.3.0 STM32Cube_FW_F4_V1.12.0 以上来自于谷歌翻译 以下为原文 en.X-CUBE-MEMSMIC1 I want to add this to stm32cube but say this verison is not for this stm32cube release STM32CubeExpansion_MEMSMIC1_V1.3.0 STM32Cube_FW_F4_V1.12.0 |
你好
http://uploads.im/ZXPmL.png ''不适用于此版本 STM32CubeMX'' 请注意 那个Ahrovan 以上来自于谷歌翻译 以下为原文 Hi http://uploads.im/ZXPmL.png ''doesn't apply to this version of STM32CubeMX '' please note thx Ahrovan |
2882 浏览 1 评论
3282 浏览 1 评论
1861 浏览 1 评论
3711 浏览 6 评论
6125 浏览 21 评论
对H747I-DISCO写程序时将CN2的st-link复用为usart1,再次烧录时无法检测到stlink怎么解决?
411浏览 2评论
STM32G474RE芯片只是串口发个数据就发烫严重是怎么回事?
510浏览 2评论
STM32处理增量式编码器Z信号如何判断中断是正转的还是反向转的?
334浏览 2评论
使用STM32F407VET6的USB2.0功能,发现ctl后芯片无数据返回,是什么原因可能导致的呢?
246浏览 2评论
用STM32G431开发工程,1.50版本的Package包文件无法输出项目工程
354浏览 2评论
GMT+8, 2025-2-24 16:41 , Processed in 1.266446 second(s), Total 78, Slave 62 queries .
