我想将PIC18F45与MM7150接口。我在多个论坛搜索代码,但没有多大帮助。微芯片上可用的是PIC24,而且代码太大,不能修改PIC18。由于我对嵌入式编程很陌生,最近几天我都很熟悉。如果你已经做了这个界面,有人能帮我看看代码吗?谢谢。
以上来自于百度翻译 以下为原文 I would like to interface PIC18F4550 with MM7150. i searched in multiple forums for the code and it did not help much. the one which is available with microchip is for PIC24, and the code is also too large to modify for PIC18. as i am new to embedded programming, i am stuck up with this for last few days. Can some one help me with the code if you had already done this interface. Thank you |
9个回答
是加速度计吗?它使用什么协议?SPI?
以上来自于百度翻译 以下为原文 Is it an accelerometer? What protocol does it use? SPI? |
从来没有用过(我用过类似的,是MMA7150)吗?在那个PIC中,我几乎不使用I2C模块:我通常实现一个SW(bit-ban.)I2C接口,您可以在这个论坛(用google搜索)上找到它的例子。
以上来自于百度翻译 以下为原文 Never used that (I used similar ones, is it "MMA7150"?) and I hardly used I2C module in that PIC: I usually implemented an SW(bit-banged) I2C interface, for which you can find examples on this forum (search with google) |
嗨,它是一种混合型三维定向传感器:三轴加速度计、磁强计和陀螺仪。主要是博世BM*传感器。模块上还有一个预编程的微控制器,看起来是PIC32MX2xx。PIC18F4550有些过时,并且不支持微芯片代码配置器。您将需要一些用于I2C通信的示例代码。在这个线程中还有另一个成员正在试验一些I2C内容http://www.micro..com/for./FindPost/966927He正在使用PIC18F45K20,它具有与PIC18F4550非常类似的I2C模块。
以上来自于百度翻译 以下为原文 Hi, It is a hybrid with several sensors for 3D orientation: 3 axis accelerometer, magnetometers and gyroscopes. Mainly Bosch BM* sensors. There is also a preprogrammed microcontroller on the module, seemingly a PIC32MX2xx. The PIC18F4550 is somewhat obsolete, and is not supported by Microchip Code Configurator. You will need some example code for I2C communication. There is another member experimenting with some I2C stuff in this thread: http://www.microchip.com/forums/FindPost/966927 He is using PIC18F45K20 which have a I2C module quite similar to what is in PIC18F4550. Regards, Mysil |
和谐的18F45 50 PIC?不要这样想…
以上来自于百度翻译 以下为原文 Harmony on a 18F4550 pic? don't think so..... |
为什么?OP清楚地表示他有PIC18F45 50。
以上来自于百度翻译 以下为原文 Why? The OP clearly stated he has a PIC18F4550. |
为什么?OP清楚地表示他有PIC18F45。我的观点是……微笑:
以上来自于百度翻译 以下为原文 Why? The OP clearly stated he has a PIC18F4550. My point exactly....Smile: |
5455 浏览 9 评论
2152 浏览 8 评论
2054 浏览 10 评论
3320 浏览 3 评论
2360 浏览 5 评论
960浏览 1评论
819浏览 1评论
818浏览 1评论
842浏览 0评论
我是Microchip 的代理商,有PIC16F1829T-I/SS 威廉希尔官方网站 问题可以咨询我,微信:A-chip-Ti
536浏览 0评论
GMT+8, 2025-4-26 14:37 , Processed in 1.361435 second(s), Total 93, Slave 77 queries .
