大家好
我必须与Spartan 6设备建立100 Mbps以太网连接(MII接口)。 有没有人有一个不仅模拟硬件的例子? 我试图从xilinx核心生成器开始工作,但直到现在还没有成功...... 也许soneone有一个可行的示例项目,即使是斯巴达3设备或其他评估板,他可以发给我? 我的电子邮件:在bluewin dot ch重新点击abt 非常感谢! 雷托 以上来自于谷歌翻译 以下为原文 Hi everybody I have to establish a 100 Mbps Ethernet Connection (MII Interface) with a Spartan 6 Device. Does anyone have an example which works on hardware not only simulation? I tried to get work the example from xilinx Core Generator, but with no sucess until now... Maybe soneone has a working example project, even for a spartan 3 device or another evaluation board, which he can send me? My email: reto dot abt at bluewin dot ch Thanks a lot! Reto |
以下是软核TEMAC核心的逐步pdf。
我获得了1gbps以太网通信的成功。 这是tcp / ip模型的物理层指南。 你需要为另一方的pc构建所有其他硬编码的阶段才能理解。(如果你在另一边使用pc)。 http://www.xilinx.com/support/documentation/ip_documentation/tri_mode_eth_mac_gsg139.pdf http://www.xilinx.com/support/documentation/ip_documentation/tri_mode_eth_mac_ug138.pdf 希望这可以帮助。 以上来自于谷歌翻译 以下为原文 Here is a step by step pdf for the softcore TEMAC core. I got success for 1gbps ethernet communication. This is the guide for the physical layer of tcp/ip model. U need to build all the other stages hard coded for the pc on the other side to understand .(if ur using pc on the other side). http://www.xilinx.com/support/documentation/ip_documentation/tri_mode_eth_mac_gsg139.pdf http://www.xilinx.com/support/documentation/ip_documentation/tri_mode_eth_mac_ug138.pdf Hope this helps. |
谢谢你的帮助!
问题是逻辑的复位输入极性相反,我用过...... 以上来自于谷歌翻译 以下为原文 Thanks for your help! The problem was the opposed polarity of the reset-input for the logic, which I used... |
2448 浏览 7 评论
2846 浏览 4 评论
2310 浏览 9 评论
3391 浏览 0 评论
2486 浏览 15 评论
1788浏览 1评论
623浏览 1评论
485浏览 1评论
2036浏览 0评论
762浏览 0评论
GMT+8, 2025-1-13 22:38 , Processed in 1.317975 second(s), Total 80, Slave 62 queries .
