我有一个包含单个Spartan3-DSP XC3SD3400A的新电路板。
我无法通过JTAG或串行SPI闪存对器件进行编程。 我可以通过iMPACT对闪存芯片进行编程,但是当我对电路板进行电源循环时,CCLK,CSO_B,MOSI或MISO引脚上没有活动,它们都处于0V。 JTAG接口也会因为TDO没有切换但是会出现TCK信号的耦合“重影”而失败。 我在下面添加了一些JTAG跟踪。 电源导轨看起来都很好看。 从任何JTAG信号到彼此或接地都没有明显的短路。 任何建议,将不胜感激。 TCK v TDO TCK v TMS TCK v TDI 谢谢 戴夫 以上来自于谷歌翻译 以下为原文 I have a new board containing a single Spartan3-DSP XC3SD3400A. I am unable to program the device either from JTAG or from a serial SPI flash. I can program the flash chip OK via iMPACT but when I power cycle the board there is no activity on the CCLK, CSO_B, MOSI or MISO pins, they are all at 0V. The JTAG interface also falls over as TDO does not toggle but exhibits a coupled 'ghost' of the TCK signal. I have added some JTAG traces below. The power rails all look good & there are no obvious shorts from any of the JTAG signals to each other or to ground. Any suggestions would be appreciated. TCK v TDO TCK v TMS TCK v TDI Thanks Dave |
Dunno为什么链不起作用,但你看到的“幽灵”信号是通过地面耦合的。
----------------------------是的,我这样做是为了谋生。 以上来自于谷歌翻译 以下为原文 Dunno why the chain doesn't work, but the "ghost" signal you see is coupling through the ground.----------------------------Yes, I do this for a living. |
2604 浏览 7 评论
2923 浏览 4 评论
2376 浏览 9 评论
3477 浏览 0 评论
2554 浏览 15 评论
3117浏览 1评论
725浏览 1评论
600浏览 1评论
GMT+8, 2025-4-22 02:57 , Processed in 1.477766 second(s), Total 74, Slave 58 queries .
