根据数据表,斯巴达6家族有
广泛的第三方SPI(高达x4)和NOR闪存支持功能丰富的Xilinx平台闪存和JTAG 但是,如果它支持NAND闪存,我不太清楚吗? 我想构建和FPGA + ARM平台,我当时认为每个组件都有自己的闪存。 您如何看待,我应该只使用一个NAND闪存进行FPGA和处理器访问,这意味着FPGA配置文件(.mcs)也存储在非易失性闪存中,在加电时,ARM处理器会自动配置FPGA吗? NAND闪存与Xilinx Spartan 6兼容吗? 有人可以帮助我,谢谢。 格拉迪斯 以上来自于谷歌翻译 以下为原文 According to the datasheet, The Spartan 6 family has Broad third-party SPI (up to x4) and NOR flash support Feature rich Xilinx Platform Flash with JTAG However, I don't quite understans if it supports NAND flash? I want to build and FPGA + ARM platform, I was thinking that each component has their own flash. How do you think, should I use just one NAND flash for both FPGA and processor access, which means FPGA configuration file (.mcs) is also stored in the non volatile Flash memory, at power up, ARM processor automatically configures FPGA? Is NAND flash compatible with Xilinx Spartan 6? Anyone could help me please, Thank you. Gladys |
NAND闪存不能用于配置FPGA,但您可以在设计中使用NAND闪存。
------您是否尝试在Google中输入问题? 如果没有,你应该在发布之前。太多结果? 尝试添加网站:www.xilinx.com 在原帖中查看解决方案 以上来自于谷歌翻译 以下为原文 NAND flash cannot be used for configuring the FPGA, but you can use NAND flash in your design. ------Have you tried typing your question into Google? If not you should before posting. Too many results? Try adding site:www.xilinx.comView solution in original post |
------您是否尝试在Google中输入问题? 如果没有,你应该在发布之前。太多结果? 尝试添加网站:www.xilinx.com 以上来自于谷歌翻译 以下为原文 NAND flash cannot be used for configuring the FPGA, but you can use NAND flash in your design. ------Have you tried typing your question into Google? If not you should before posting. Too many results? Try adding site:www.xilinx.com |
2570 浏览 7 评论
2904 浏览 4 评论
2359 浏览 9 评论
3453 浏览 0 评论
2540 浏览 15 评论
2974浏览 1评论
700浏览 1评论
574浏览 1评论
864浏览 0评论
GMT+8, 2025-4-7 02:01 , Processed in 1.485149 second(s), Total 79, Slave 63 queries .
