扫一扫,分享给好友
查了一下stackoverflow,这个可以说是一个bug,也可以说是一个特性,原文如下: It's not a bug. The only reason it would hang when you close it is because in the event handler of your SerialPort object, you're synchronizing a call with the main thread (typically by calling invoke). SerialPort's close method waits for its EventLoopRunner thread which fires DataReceived/Error/PinChanged events to terminate, but since your own code in the event is also waiting for main thread to respond, you run into a dead lock situation. The reason the bug report was closed 'as designed' is because the 'bug' is in your own code. 大概意思就是同步调用时由于要响应事件循环,因此等待时间就会比较长,解决方法就是新开一个线程,不要在主线程(界面UI)中调用close方法,对应的labview写法当然是异步调用了,即把close这一段封装成一个子VI,然后进行异步调用。 如下图所示: ![]() 评分 |
2 条评论
你的版本太高了,我的2017都没法打开,在论坛上问问题,请尽量将附件vi转成较低的版本,方便大家,也方便自己。
问题出在C#serialport类的close方法会造成线程死锁会卡,但是不知道怎么解决!
用了nuget的serialportstream,原来2,30秒的等待变成7,8秒了,但还是大!
用了nuget的serialportstream可以了,可能是上次测试是参数设错了!
809 浏览 1 评论
2349 浏览 2 评论
2074 浏览 4 评论
labview如何实现电机位置与图像清晰度计算值相对应,或者说如何实现电机每步距计算一次清晰度值?
2271 浏览 2 评论
2797 浏览 1 评论
GMT+8, 2025-2-25 03:43 , Processed in 0.868450 second(s), Total 59, Slave 52 queries .
