[tr]我用6748开发板调试网络通信例程(基于stareware和sys/bios下)遇见以下问题,请有经验的大侠指点一下:
1、基于stareware的例程ENET_HTTPD调试 编译可以通过,但是在debug运行时提示: Can't find a source file at "D:/StarterWare_Gitorious_C6748/StarterWare_01_20_04_01/drivers/psc.c" Locate the file or edit the source lookup path to include its location. 我把psc.c文件导入之后,没有任何现象(串口也没有提示) 2、基于sys/bios的例程调试(以tcp_client为例) 编译可以通过,在debug运行时提示: TMS320C64X+_0: Warning: CPUEnabled)Interrupt No. 14 dropped, an earlier interrupt is pending to be taken TMS320C64X+_0: Warning: CPUEnabled)Interrupt No. 14 dropped, an earlier interrupt is pending to be taken 我查看了一下,程序走到csl_emac.c停在while (ECTL_REGS->SOFTRESET != 0x00000000); /* Wait until reset has occured */ 按照意思是,给一个中断信号才能执行下去,问题是我如何触发一个中断。 并且这时有提示: Can't find a source file at "/db/vtree/library/trees/nsp/nsp-b09x/src/ti/drv/omapl138/ethdriver.c" Locate the file or edit the source lookup path to include its location. Can't find a source file at "/db/vtree/library/trees/nsp/nsp-b09x/src/ti/drv/omapl138/nimu_eth.c" Locate the file or edit the source lookup path to include its location. Can't find a source file at "/db/vendors/ti/c6x/7.2.0/Linux/include/string.h" Locate the file or edit the source lookup path to include its location. 我把这几个文件导入工程之后,仍然提示: TMS320C64X+_0: Warning: CPUEnabled)Interrupt No. 14 dropped, an earlier interrupt is pending to be taken TMS320C64X+_0: Warning: CPUEnabled)Interrupt No. 14 dropped, an earlier interrupt is pending to be taken 请问这是什么原因? 3、另外请问一下stareware 是基于非操作系统的,但是我能在sys/bios下应用stareware 吗? [/tr] |
3个回答
基于RK3588J的6路MIPI CSI视频采集案例分享,多路视频系统必看!
1450 浏览 0 评论
651 浏览 0 评论
【创龙科技TL570x-EVM开发板试用体验】 GStreamer 功能测评
8642 浏览 8 评论
【创龙科技TL570x-EVM开发板试用体验】创龙TL5708-EVM开发板入手使用体验评测
6701 浏览 0 评论
【创龙TLZ7x-EasyEVM评估板试用连载】+3.环境搭建vmware+ubuntu详细教程(二)
1432 浏览 0 评论
940浏览 0评论
【创龙科技AM64x开发板试用体验】创龙科技AM64x开发板及核心板介绍
883浏览 0评论
【创龙科技AM64x开发板试用体验】创龙科技AM64x开发板--板卡调试软件安装
902浏览 0评论
【创龙科技AM64x开发板试用体验】AM64x开发板开箱测评
895浏览 0评论
求助! 关于使用自制底板插入创龙IMX8MM 核心板无法启动问题
525浏览 0评论
GMT+8, 2025-1-11 18:15 , Processed in 0.586511 second(s), Total 82, Slave 63 queries .
