已经换了两个仿真器,然后把拨码开关也调到了01111,但是还是一样的结果 Execute the command: %ccs_base%/common/uscif/dbgjtag -f %boarddatafile% -rv -o -F inform,logfile=yes -S pathlength -S integrity [Result] -----[Print the board config pathname(s)]------------------------------------ C:UsersmmAppDataLocal.TI1710447290 0\0BrdDattestBoard.dat -----[Print the reset-command software log-file]----------------------------- This utility has selected a 100- or 510-class product. This utility will load the adapter 'jioserdesu***.dll'. An already open status was returned while soft opening the controller. -----[An error has occurred and this utility has aborted]-------------------- This error is generated by TI's USCIF driver or utilities. The value is '-110' (0xffffff92). The title is 'SC_ERR_OCS_ALREADY_OPEN'. The explanation is: This utility opened the controller but found it already in use. You must exit other debuggers and utilities that access the controller because this utility must be the only client. [End] 请问还有可能是什么问题呢? 提示的意思是 CCS Debug 调试以及在运行中 重启电脑 |
基于RK3588J的6路MIPI CSI视频采集案例分享,多路视频系统必看!
1715 浏览 0 评论
718 浏览 0 评论
【创龙科技TL570x-EVM开发板试用体验】 GStreamer 功能测评
8730 浏览 8 评论
【创龙科技TL570x-EVM开发板试用体验】创龙TL5708-EVM开发板入手使用体验评测
6756 浏览 0 评论
【创龙TLZ7x-EasyEVM评估板试用连载】+3.环境搭建vmware+ubuntu详细教程(二)
1459 浏览 0 评论
995浏览 0评论
【创龙科技AM64x开发板试用体验】创龙科技AM64x开发板及核心板介绍
953浏览 0评论
【创龙科技AM64x开发板试用体验】创龙科技AM64x开发板--板卡调试软件安装
951浏览 0评论
【创龙科技AM64x开发板试用体验】AM64x开发板开箱测评
938浏览 0评论
求助! 关于使用自制底板插入创龙IMX8MM 核心板无法启动问题
560浏览 0评论
GMT+8, 2025-3-5 06:06 , Processed in 0.639298 second(s), Total 56, Slave 48 queries .
