扫一扫,分享给好友
大家好
波DAC组件对我来说非常有趣。有可能使这个组件有点莫名其妙吗?(如Add、Mulk、FM、AM、RM—这是音频合成的理想选择) 卡米尔 以上来自于百度翻译 以下为原文 Hi all Wave DAC component is very interesting for me. Is possible make this component with some modiffier ? (like add, multi, FM, AM, RM - this is ideal for audio synthesis) Kamil |
8个回答
你好,Kamil。
正如鲍伯已经提到的,您可以根据您的需求使用WaveDAC组件。 有一个应用说明,解释调幅和解调“PSoC方式”使用混频器组件作为峰值检测器单元。 此应用笔记可在HTTP://wwwyCypCy.COM/?RID=44407 以上来自于百度翻译 以下为原文 Hi Kamil. As Bob has already mentioned, you can use the WaveDAC component according to your requirement. There is an application note which explains Amplitude Modulation and Demodulation the "PSoC Way" using Mixer component as peak detector unit. This application note is available at http://www.cypress.com/?rID=44407 |
您可以查看HTTP://HeDrikLIPKA.DE/MISC/DD.CyWrk.CaseV02.Zip,它基于PSoC5(-050板)上的WaveDAC思想实现了VCO。我目前正在努力通过实施一个数控振荡器来扩展,以达到更高的精度。
以上来自于百度翻译 以下为原文 You can look at http://hendriklipka.de/misc/dds.cywrk.Archive02.zip , which implements a VCO based on the WaveDAC idea on the PSoC5 (-050 board). I'm currently working on extending it by implementing a numerically controlled oscilator to achieve higher precision. |
AM基本上是修改的正弦/COS/复波表,乘法应用于其检索的条目。
相位调制是将索引修改到表中。 调频调制改变了表检索率。 HTTP//www.类比.COM/STATIC/SENDTEDIOFIDS/TURBIALS/MT-085.PDF 问候,Dana。 以上来自于百度翻译 以下为原文 AM is basically modifiy sine/cos/complex waveform table with a multiplication applied to its retrieved entries. Phase modulation is modifiy the index into the table. FM modulation is alter the table retrieval rate. http://www.analog.com/static/imported-files/tutorials/MT-085.pdf Regards, Dana. |
使用WaveDAC组件可以达到最大的信号频率?
以上来自于百度翻译 以下为原文 What is the maximun signal frecuency that can be achieved using waveDAC component? |
硬件明智的是,它限制了DAC的稳定时间。
在IDAC的情况下,100 ns,VDAC 1 US。每个样品, 乘以波形表中的时间样本。 问候,Dana。 以上来自于百度翻译 以下为原文 Hardware wise its limited by settling time of the DACs. In the case of IDAC thats 100 nS, VDAC 1 uS. Thats per sample, multiply that times # samples in waveform table. Regards, Dana. |
记住,如果表大小很小,比如2个样本,你可能会
在向DAC写价值时有一个限制,反过来 会限制频率。 问候,Dana。 以上来自于百度翻译 以下为原文 Keep in mind, if table size real small, like 2 samples, you might have a thruput limitation in writing values to the DAC, in turn that would limit frequency. Regards, Dana. |
760个成员聚集在这个小组
加入小组2151 浏览 1 评论
1897 浏览 1 评论
3718 浏览 1 评论
1829 浏览 6 评论
1574 浏览 1 评论
778浏览 2评论
536浏览 2评论
482浏览 2评论
443浏览 2评论
1138浏览 2评论
GMT+8, 2025-2-24 06:34 , Processed in 0.922138 second(s), Total 89, Slave 73 queries .
