你好,
我高兴地发现,PSoC1(CY8C29)现在能够“房子”PLC IP解决方案。在我看来,这是一个非常有趣的问题,即使它是一个资源匮乏的解决方案。我的问题是…需要什么来适应TTL电平到电力线? AN55 427中提出的方案是否仍然可用? 最好的问候, 米歇尔桑图奇 以上来自于百度翻译 以下为原文 Hallo, I happily discovered that PSOC1 (CY8C29) is now able to 'house' PLC IP solution.. that's something really interestig in my opinion even if it's a somewhat resource hungry solution. My question is ... what's required to adapt TTL levels to powerline? The schematic solution proposed in AN55427 are still usable? Best Regards, Michele Santucci |
电力线的规格没有大的变化,所以按照AN55 427给出的方向似乎仍然是合适的。逻辑电平为5V时,为PSoC29的硬件建议…对于CY8CPLC…
鲍勃 以上来自于百度翻译 以下为原文 There haven't been dramatic changes in the specs of the powerlines, so it seems still to be appropiate to follow the directions given in AN55427. The logic levels are 5V when following the hardware proposals for PSoC29.... as for the CY8CPLC... Bob |
757个成员聚集在这个小组
加入小组2137 浏览 1 评论
1877 浏览 1 评论
3700 浏览 1 评论
1815 浏览 6 评论
1561 浏览 1 评论
756浏览 2评论
509浏览 2评论
470浏览 2评论
422浏览 2评论
1113浏览 2评论
GMT+8, 2025-2-3 03:05 , Processed in 1.158234 second(s), Total 83, Slave 63 queries .
