嗨,
Spartan 3E-250设备有内置缓冲块吗? 在FPGA编辑器中我没有看到任何内容。 谢谢。 阿卜杜拉 以上来自于谷歌翻译 以下为原文 Hi, Does Spartan 3E-250 device have built-in buffer blocks? I don't see any in FPGA editor. Thank you. abdullah |
所有FPGA都有缓冲器来沿其路径推送信号。
不是使用一个带有被动模拟式交叉点连接在一起的非常长的线路的驱动器,而是为这些连接中的每一个使用有源驱动器。 通过保持总线短路,显着降低了R / C延迟中的“C”。 还有全局时钟缓冲器,输入缓冲器和输出缓冲器,这些都在Spartan 3E-250 FPGA Editor视图中有所说明。 交叉连接有很小的“点”,其中许多 - 如果你放大它们 - 显示方向缓冲区而不是简单的块或交叉连接。 以上来自于谷歌翻译 以下为原文 All FPGAs have buffers to push the signal along its path. Rather than using one driver with very long lines that are connected together with passive analog-style cross-points, active drivers are used for each of these connections. The "C" in the R/C delays are significantly lowered by keeping the overall lines short. There are global clock buffers, input buffers, and output buffers that are all illustrated in the Spartan 3E-250 FPGA Editor view as well. The cross connects have small "pips" many of which - if you zoom in on them - show directional buffers rather than simple blocks or cross-connects. |
感谢您的回复。
我附上了另一个有我想说的块的设备的图片。 但是我还没有看到任何阻挡,因为我想在我的身上使用它们 实施时的代码。 当我编写Xilinx原语(如BUF等)时,它没有在Spartan 3E中实现我想要的缓冲区。 谢谢。 阿卜杜拉 以上来自于谷歌翻译 以下为原文 Thank you for reply. I attached a picture of another device that has a block which I want to say. But I can not see any block yet, since I want to use them in my code while implementing. When I write Xilinx primitives (like BUF, etc.), it does not implement a buffer which I want in Spartan 3E. Thank you. abdullah |
2474 浏览 7 评论
2860 浏览 4 评论
2322 浏览 9 评论
3406 浏览 0 评论
2502 浏览 15 评论
2194浏览 1评论
645浏览 1评论
508浏览 1评论
2054浏览 0评论
783浏览 0评论
GMT+8, 2025-2-4 12:49 , Processed in 1.215266 second(s), Total 47, Slave 41 queries .
