我们的校准实验室配有Agilent PSG E8267D(20GHz版本)信号发生器,带AM选项(UNT选件)。
发电机在安捷伦每年校准一次,但为什么AM调制检查不属于安捷伦性能测试? 发电机很好地通过了校准,但AM调制不能正常工作。 当我们使用1kHz mudulation freq进行测量时,调制百分比误差几乎为40%。 测试设备是Agilent 8902A测量接收器。我们的实验室还有几个不太相似的带AM选项的PSG发生器,它们工作正常。 我很担心,AM方面不包括安捷伦的性能测试程序。 以上来自于谷歌翻译 以下为原文 Our calibration lab has Agilent PSG E8267D (20GHz version) signal generator with AM option (UNT option). Generator is calibrated ones a year in Agilent, but why AM modulation check dosen't belongs to the Agilent performance test? Generator is passed the calibration nicely, but AM modulation dosen't work properly. Modulation percent error is almost 40% when we measured it using 1kHz mudulation freq. Test device was Agilent 8902A measuring receiver. Our lab has several more a less similar PSG generators with AM option and they work fine. I'm quite worry, that AM side dosen't include the Agilent's performance test routine. |
您好 - 我建议您将您的设备发送到安捷伦服务中心,要求专门查看AM。
以上来自于谷歌翻译 以下为原文 Hello - I suggest you send your unit to an Agilent service center requesting specifically AM to be looked at. |
1333 浏览 0 评论
2397 浏览 1 评论
2216 浏览 1 评论
2086 浏览 5 评论
2974 浏览 3 评论
1238浏览 1评论
784浏览 0评论
1035浏览 0评论
1335浏览 0评论
GMT+8, 2025-1-13 19:33 , Processed in 1.258831 second(s), Total 44, Slave 38 queries .
