DMA的数据传输速率是多少?由于DMA与CPU无关,所以CPU的速率可能不高。你知道DMAC的时钟是什么吗?
以上来自于百度翻译 以下为原文 What is the rate of data transfer by the DMA. Since DMA is independent of CPU it does not work at the rate of CPU might be higher. Any idea on what is the clock to DMAC? |
DMA由BuSyCLK计时,因此您需要检查您的设计设置。但要小心,还有其他因素。因此,请查阅威廉希尔官方网站
参考手册(PSoC5架构TRM)以了解更多细节。
以上来自于百度翻译 以下为原文 The DMA is clocked by BUS_CLK, so you need to check in your design settings. But beware - there are other factors involved. So check the technical reference manual (PSoC5 architecture TRM) for more details. |
733个成员聚集在这个小组
加入小组1952 浏览 1 评论
1698 浏览 1 评论
3468 浏览 1 评论
1625 浏览 6 评论
1415 浏览 1 评论
GMT+8, 2024-7-22 05:56 , Processed in 0.586024 second(s), Total 48, Slave 42 queries .
