嗨,
我只是想与我的Nu Horizons Spartan 3 1500板通信。 我使用的是Digilent USB JTAG线缆。 这与IMPACT兼容吗? 每次我尝试使用它时都不会检测到电缆。 我曾尝试使用Digilent Export(软件将程序上传到电路板),但是我的代码在完成下载后都没有执行。 它说我有一个成功的转移,初始启动程序停止,下载LEDS点亮,但在那之后,电路板似乎锁定。 LCD屏幕会在下载过程中显示留在其上的任何消息,并且不会更改。 我只能通过拔掉它来重置电路板。 任何建议或想法将不胜感激。 谢谢 康纳 以上来自于谷歌翻译 以下为原文 Hi, I am just trying to communicate with my Nu Horizons Spartan 3 1500 board. I am using a Digilent USB JTAG cable. Is this compatible with IMPACT? It does not detect the cable each time I try to use it. I have tried using Digilent Export (software to upload program to board), however none of my code has executed after it completes its download. It says that I had a successful transfer, the initial startup program stops, and the download LEDS light up, but after that the board seems to lock up. The LCD screen diplays whatever message was left on it during the downloading process and will not change. I can only reset the board by unplugging it. Any advice or ideas would be greatly appreciated. Thanks Connor |
你会想要携带Xilinx下载电缆和软件。
-------------------------------------------------- ----------------------------别忘了回复,给予kudo并接受为解决方案--------- -------------------------------------------------- ------------------- 以上来自于谷歌翻译 以下为原文 you will want to try Xilinx download cable and software.------------------------------------------------------------------------------ Don't forget to reply, give kudo and accept as solution ------------------------------------------------------------------------------ |
2420 浏览 7 评论
2823 浏览 4 评论
2294 浏览 9 评论
3374 浏览 0 评论
2461 浏览 15 评论
1179浏览 1评论
587浏览 1评论
451浏览 1评论
2005浏览 0评论
731浏览 0评论
GMT+8, 2024-12-23 23:49 , Processed in 1.058128 second(s), Total 46, Slave 40 queries .
