嗨,我买了iNemo-M1板。
我通过USB板将它连接到PC,但PC无法识别电路板。 电路板是否已编程? 我需要选择一个iNemo DFu固件来编程吗? 谢谢。 Eduardo Scherrer #inemo-M1-板。 以上来自于谷歌翻译 以下为原文 Hi, I bought the iNemo-M1 Board. I connect it to PC by USB board, but PC not recognized the board. The board is aready programmed? I need to select an iNemo DFu firmware to program? Thanks. Eduardo Scherrer #inemo-m1-board. |
我们有同样的问题。我们刚买了几块iNEMO M1板(只是传感器,而不是STEVAL-MKI121开发套件),我们无法让它们运行。我们按照文档焊接了它们,但计算机无法识别它们。它们是预先编程的还是我们必须闪存微控制器?如果是这样,请遵循什么程序?数据表至少可以说是稀缺的。
以上来自于谷歌翻译 以下为原文 We have the same problem. We just bought a couple of iNEMO M1 boards (just the sensors, not the STEVAL-MKI121 dev kit) and we can't get them to run. We have soldered them following the documentation, but the computer doesn't recognize them. Are they preprogrammed or do we have to flash the microcontroller? If so, what is the procedure to follow? The datasheets are scarce to say the least. |
我也有同样的问题。我试图在INEMO-M1模块和Raspberry Pi之间进行通信,我已经尝试了所有可能性(电源选项,启用选项,通信协议,如I2C,SPI,USART,USB等),但我每次尝试都失败了。虽然我没有评估板,但我下载了评估板的软件,并尝试将模块连接到PC,但无法识别设备。此外,还缺少文档以及如何使用此模块。我甚至无法理解模块是否正常工作。可能是我在焊接它时烧了模块,我不确定但应该有办法检查模块。任何帮助将不胜感激。谢谢。
以上来自于谷歌翻译 以下为原文 I have the same problem. I am trying to get communication between INEMO-M1 module and Raspberry Pi, I have tried all the possibilities (power supply options, enable options, communication protocols like I2C, SPI, USART, USB etc.) but I have failed each try. Although I don't have the eval board I downloaded the software of the eval board and tried to connect the module to the PC but the device is not recognized. Also there is lack of documentation and how to use this module. I could not even understand whether the module works properly or not. May be I have burned the module while soldering it, I am not sure but there should be a way to check the module. Any help will be appreciated. Thank you. |
2785 浏览 1 评论
3252 浏览 1 评论
1827 浏览 1 评论
3672 浏览 6 评论
6068 浏览 21 评论
1350浏览 4评论
对H747I-DISCO写程序时将CN2的st-link复用为usart1,再次烧录时无法检测到stlink怎么解决?
374浏览 2评论
STM32G474RE芯片只是串口发个数据就发烫严重是怎么回事?
470浏览 2评论
STM32处理增量式编码器Z信号如何判断中断是正转的还是反向转的?
294浏览 2评论
使用STM32F407VET6的USB2.0功能,发现ctl后芯片无数据返回,是什么原因可能导致的呢?
218浏览 2评论
GMT+8, 2025-1-14 02:01 , Processed in 0.978593 second(s), Total 44, Slave 39 queries .
