嗨,
我想探索SPC5 Studio。因此,我创建了一个新的SPC5 C / C ++ Makefile项目。在configuration.xml中,我通过图形编辑器添加了“STMicroelectronics SPC560B / Cxx平台组件”。 对于这个组件,我添加了一个''SPC5-HAL SPC560BCxx OS-Less Runtime Package Component''。在其中一个子组件(''SPC5-HAL Portable HAL Component'')中,我尝试激活一些驱动程序。但是只有两个驱动程序可配置(''PAL''和''Serial'')。无法选择所有其他驱动程序。 (1)我现在的第一个问题是,我是否忘记了激活其他驾驶员的重要事项,或者是否有其他方法可以做到这一点。 (2)其次,我想要求更多关于SPC5 Studio的文档,而不是可以在Studio本身找到的文档。 最好的祝福, 塞巴斯蒂安 以上来自于谷歌翻译 以下为原文 Hi, I want to explore the SPC5 Studio. Therefore I created a new SPC5 C/C++ Makefile project. In the configuration.xml I added via the graphical editor a ''STMicroelectronics SPC560B/Cxx Platform Component''. To this component I added a ''SPC5-HAL SPC560BCxx OS-Less Runtime Package Component''. In one of its sub-components (''SPC5-HAL Portable HAL Component'') I tried to activate some drivers. But there are only two drivers configurable (''PAL'' and ''Serial''). All other drivers can't be selected. (1) My first question is now whether I forgot something important to activate other drivers or is there an other way to do that. (2) Second I wanted to request if there are some more documentations about the SPC5 Studio than those which can be found in the Studio itself. Best regards, Sebastian |
嗨塞巴斯蒂安,
感谢您的反馈。 这套驱动程序尚未完成,在下一版本1.2(两周内)内,我们将拥有更多驱动程序,并且计划在1.3版本(9月底)完成设置。 关于文档,1.3版将包含内部文档。同时,您可以参考高级API文档的此页面:http://chibios.sourceforge.net/html/group___i_o.html 以上来自于谷歌翻译 以下为原文 Hi Sebastian, Thanks for the feedback. The set of the drivers is not yet complete, in next version 1.2 (within two weeks) we will have more drivers and the set is planned to be completed in version 1.3 (end of September). About documentation, version 1.3 will contain internal documentation. In the meanwhile you can refer to this page of the high level API documentation: http://chibios.sourceforge.net/html/group___i_o.html |
2881 浏览 1 评论
3282 浏览 1 评论
1861 浏览 1 评论
3711 浏览 6 评论
6125 浏览 21 评论
对H747I-DISCO写程序时将CN2的st-link复用为usart1,再次烧录时无法检测到stlink怎么解决?
411浏览 2评论
STM32G474RE芯片只是串口发个数据就发烫严重是怎么回事?
510浏览 2评论
STM32处理增量式编码器Z信号如何判断中断是正转的还是反向转的?
334浏览 2评论
使用STM32F407VET6的USB2.0功能,发现ctl后芯片无数据返回,是什么原因可能导致的呢?
246浏览 2评论
用STM32G431开发工程,1.50版本的Package包文件无法输出项目工程
354浏览 2评论
GMT+8, 2025-2-24 10:43 , Processed in 0.942493 second(s), Total 42, Slave 37 queries .
