扫一扫,分享给好友
开发人员请教了我们一个关于PSoC设计器程序的问题。他说,“我在PSoC设计器4.4中做了动态配置,但是在PSoC设计器5中,我不能再这样做了。当我们首先使用动态配置卸载和加载CAPSENSE时,对应于CSDJEnter例程的关键信息已经被删除。“客户还说他们试图在赛普里斯网站上打开一个“CASE”,但不能实现这一点(他说网站的一部分是不正常工作,所以这就是为什么我要写这个信息。怎样才能解决这个问题呢?
以上来自于百度翻译 以下为原文 one of developer consult us and asked a question about PsoC designer program. He says that “I’was making dynamic configuration in PsoC Designer 4.4 but in PsoC Designer 5.0 I cannot do this anymore. When we first unload and then load the CapSense by using dynamic configuration the key information which are corresponded to CSD_Start routine has been deleted.” Customer also said that they tried to open a “Case” in Cypress web site but could not achive this (he says Case part of web site is not working properly) so this is why I'm writing this message. What can be done to solve this problem? |
PSoC设计器5.2 Service PACK 1现在可用,您可以在以下尝试:
HTTP://www. CyPress?COM/?RID=41083 以上来自于百度翻译 以下为原文 PSoC Designer 5.2 Service Pack 1 is available now, you may try this at: http://www.cypress.com/?rID=41083 |
751个成员聚集在这个小组
加入小组2062 浏览 1 评论
1818 浏览 1 评论
3628 浏览 1 评论
1757 浏览 6 评论
1504 浏览 1 评论
491浏览 2评论
347浏览 2评论
407浏览 2评论
352浏览 2评论
844浏览 2评论
GMT+8, 2024-11-14 18:04 , Processed in 0.594699 second(s), Total 45, Slave 40 queries .
