我正在尝试实现以太网100Base-X PCS / PMA并下载xilinx的许可证,但这是针对“Virtex-5”而我需要一个“Spartan3E”并且我想知道如何正确实现它,可以帮助我
请尽快。 谢谢。 MAG。 以上来自于谷歌翻译 以下为原文 I am trying to implement Ethernet 100Base-X PCS / PMA and donwload license of xilinx, but this is for a "Virtex-5" and I need for a "Spartan3E" and I want to know how to implement it properly, could help me as soon possible please. Thanks. MAG. |
Hi Mag,如果您使用的是Spartan-3E,则需要使用连接到“Ethernet 1000BASE-X PCS / PMA”内核的“Tri-mode Ethernet Soft IP”或“1G EMAC”内核。
本页列出了所有这三个核心:http://www.xilinx.com/products/design_resources/conn_central/protocols/gigabit_ethernet.htm通常,如果您只是使用1000BASE-X PCS / PMA核心(我们称之为 “软PCS / PMA”),您可能需要1G EMAC而不是三模式核心,因为您只能以1 Gig的速度运行。-Kyle 以上来自于谷歌翻译 以下为原文 Hi Mag, If you are using the Spartan-3E, you will need to use the "Tri-mode Ethernet Soft IP" or "1G EMAC" core connected to the "Ethernet 1000BASE-X PCS/PMA" core. All three of these cores are listed on this page: http://www.xilinx.com/products/design_resources/conn_central/protocols/gigabit_ethernet.htm Typically, if you are just using the 1000BASE-X PCS/PMA core (we call it the "soft PCS/PMA"), you would probably want the 1G EMAC instead of the tri-mode core, since you will only be running at 1 gig speeds. -Kyle |
2498 浏览 7 评论
2870 浏览 4 评论
2329 浏览 9 评论
3424 浏览 0 评论
2510 浏览 15 评论
2441浏览 1评论
658浏览 1评论
519浏览 1评论
2074浏览 0评论
800浏览 0评论
GMT+8, 2025-2-23 19:15 , Processed in 1.337806 second(s), Total 76, Slave 60 queries .
