你好先生
我正在使用ST微电子的STM8S103F2P6微控制器,当我研究微控制器的电源部分时,它指定连接一个外部电容,其值介于470到3300 nf之间。外部VCAP电容的规格如下: 值= 470至3300 nf ESL =最大15 nH。 ESR = 1欧姆时的0.3欧姆。 但我已将1 uF值电容连接到微控制器的Vcap引脚,因为我没有得到该范围的微控制器。 所以我想知道它没问题,或者它会以任何方式影响我的微控制器。我的意思是效果是什么以及它将如何影响我的整个电路和微控制器。 请详细描述一下我。 谢谢 以上来自于谷歌翻译 以下为原文 Hello sir I am using the STM8S103F2P6 microcontroller of the ST microelectronics and when I was studying the power supply section of the microcontroller there it is specified to connect an external capacitor with the value ranging in between the 470 to 3300 nf . the specifications for the external VCAP capacitor are as follows: Value = 470 to 3300 nf ESL = 15 nH max. ESR = .3 ohm at 1 MHz. But I have connected the 1 uF value capacitor to the Vcap pin of the microcontroller , because I was not getting the microcontroller of that range . So I want to know that is it ok , or it is going to effect my microcontroller in any way. I mean what will be the effect and how it will effect my whole circuit and the microcontroller. Please describe me in detail. Thank you |
我认为ST微电子的专家对发布与其产品相关的查询的回复不感兴趣。
我想我没有问过一个简单而无需回复的问题。 因为这个论坛的点击列表讲述了htis论坛中正在进行多少活动的故事。 没有印象需要改进。 |
亲爱的先生,
1 uF电容似乎在所需范围内。但是,您需要在数据表中检查制造变化是什么(例如+ -10%,有时+ -20%)以及在给定温度范围内容量变化的范围 - 与标称容量的差异可能在几十个百分点的范围内,取决于电容器材料等 要检查的最后一点是具有直流偏置的变化 - 在0402这样的小型情况下,主要对于电容器很重要,当连接1.8V时,容量损失可能高达标称值的50%。在您的应用的整个温度范围内,必须至少遵守470nF的电容。 您可以从电容器供应商/供应商处的数据表中找到这些数据。 您也会在那里找到ESL和ESR,但是,通常的陶瓷电容器对这些参数没有任何问题。 以上来自于谷歌翻译 以下为原文 Dear sir, 1 uF capacitor seems to be in the required range. However, you need to check in the datasheet what is the manufacturing variation (e.g. +-10%, sometimes +-20%) and what will be capacity variation within given temperature range - difference from nominal capacity could be in the range of tens percent, depending on the capacitor materials etc. Last point to be checked is variation with a DC bias - it is important mainly for capacitor in small cases like 0402, where loss of capacity could be up to 50% against the nominal, when 1.8V is connected. A minimum of 470nF capacitance has to be respected over the whole temperature range of your application. You will find those data in the datasheet from your vendor/supplier of capacitor. You will find there as well ESL and ESR, however, usual ceramic capacitors has no issue with those parameters. |
2413 浏览 1 评论
3129 浏览 1 评论
1698 浏览 1 评论
3511 浏览 6 评论
5867 浏览 21 评论
857浏览 4评论
1232浏览 4评论
在Linux上安装Atollic TRUEStudio的步骤有哪些呢?
501浏览 3评论
使用DMA激活某些外设会以导致外设无法工作的方式生成代码是怎么回事
1214浏览 3评论
1269浏览 3评论
GMT+8, 2024-9-21 05:44 , Processed in 1.050605 second(s), Total 78, Slave 62 queries .
