扫一扫,分享给好友
我试图了解专用线程和当前线程标志之间的差异,因为它涉及同步从FIFO读/写时序。AN6994表示,对于当前线程标志,存在两个周期延迟。它不指定读或写,虽然两个周期的延迟与同步从属读取时序图一致。
如果使用当前线程标志,除了专用线程标志所示的两个周期延迟之外,是否还要引发额外的两个周期延迟? 如果不是,这两者之间的时差是多少? 以上来自于百度翻译 以下为原文 I'm trying to understand the difference between dedicated and current thread flags as it relates to the synchronous slave FIFO read/write timing. AN65974 says that for a current thread flag there's a two cycle latency. It doesn't specify read or write although a two cycle latency is consistent with the synchronous slave read timing diagram. If I use a current thread flag, do I incur an extra two cycle latency in addition to the two cycle latency shown for the dedicated thread flag? If not whats the timing difference between the two. |
瑞问得好。听起来你有一个旧版本的AN6944,它发布之前,它有任何意义。一个新的,更连贯的版本现在可以更详细地解释时序和标志配置。
以上来自于百度翻译 以下为原文 Great question Ray. Sounds like you have an old version of AN65974 that was released before it made any sense. A new, more coherent version is now available that explains the timing and flag configuration in more detail. |
754个成员聚集在这个小组
加入小组2110 浏览 1 评论
1858 浏览 1 评论
3673 浏览 1 评论
1791 浏览 6 评论
1540 浏览 1 评论
576浏览 2评论
430浏览 2评论
440浏览 2评论
390浏览 2评论
950浏览 2评论
GMT+8, 2024-12-28 08:44 , Processed in 0.862239 second(s), Total 76, Slave 60 queries .
