首先,这肯定是一个用户问题,但这里发生了什么:
打开造物主2.1和2同时使用2个显示器,寻找差异。 没有很多但最直接最明显的变化是一个所谓的文件管理器和样品的设计,可以用来代替一个空屏当世代的一个新项目。能与Fan Contoller和它的design04要求组件更新当我使用创造者2.1。事实上,我的风扇控制器组件V1.20当有新版本可用2。 这里有一个问题: 它可以发生,新的组件覆盖旧的当造物主的译本在同一时间开放? 任何人经历了奇怪的行为而有创造者打开2版本? 不是一个大问题,现在对我来说,但我想避免这种情况在未来。 以上来自于百度翻译 以下为原文 First of all, this could definitely be a user issue but here is what happened: I opened Creator 2.1 and 2.0 at the same time using 2 monitors and searching for differences. There are not many but the most upfront visible changes are a so called document manager and sample designs which can be used instead of an empty screen when I create a new project. I selected the Design04 with Fan Contoller and it asked for a component update when I was using Creator 2.1. Indeed, my Fan Controller component was V1.20 while there is a new version 2.0 available. Here is the question: Can it happen that the new components are overwritten by the old ones when both versions of Creator are open at the same time? Anybody else experienced strange behavior while having 2 versions of Creator open? Not a big deal for me right now but I would like to avoid this in future. |
出现了两个版本的创建者2和2.1之间的差异列表,因此可以更容易地跟踪所有更改,其中一些在第一次菜单或标签中不可见。
2和2.1是共存的,这意味着您可以同时使用这两个,但是您应该避免访问具有不同版本的相同项目,因为项目的内部结构不同。已经保存了2.1下的项目,它可能不会再次打开2,尽管有一个备份被创建(当用2.1打开时),您可以从2重新启动它。 更新项目的组件覆盖项目的组件,而不是组件列表中的组件。 不更新组件将使您的项目与旧版本一样。 我总是建议使用最新版本的组件,有时会有讨厌的bug被删除。看看下面的数据表,(到最后)是一个到目前为止的变化列表。 鲍勃 以上来自于百度翻译 以下为原文 There comes a list of differences between the two versions Creator 2.0 and 2.1, so it can be much easier to follow up all the changes where some of them are not visible in a menu or tab at first sight. 2.0 and 2.1 are co-existent, that means you can use both at the same time, but you should avoid accessing the same project with different versions because the internal structure of a project differs. Having saved a project under 2.1 it may not be opened again with 2.0 although there has a backup been created (when opened with 2.1) from which you may re-start with 2.0. Updating components for a project overwrites the PROJECT's components, not those in your component list. Not updating components will leave your project as-it-is with the older versions. Bit I would always suggest to use the latest version of a component, sometimes there are nasty bugs removed. Have a look into the according datasheets, there (at the very end) is a list of changes made so far. Bob |
775个成员聚集在这个小组
加入小组cyUSB3014一直显示2.1,不能到3.0情况,谁遇到过
3035 浏览 0 评论
2284 浏览 1 评论
2012 浏览 1 评论
3852 浏览 1 评论
1910 浏览 6 评论
3683浏览 2评论
2207浏览 2评论
575浏览 2评论
552浏览 2评论
3946浏览 2评论
GMT+8, 2025-7-3 17:46 , Processed in 1.420616 second(s), Total 74, Slave 58 queries .
