亲爱的,我有一个问题来解决I2C的问题。我使用的是带有PIC18F27 K40的MCC。PIC有和ErrATA,但我不认为与I2C有关。当我试图在EE2PROM上用I2C,USPURNC2C1MAStiON编写时,CHII2CY-FLAG总是在消息待定。有人知道这是为什么吗?谢谢!
以上来自于百度翻译 以下为原文 Dear all, I'm having a problem to figure out a problem with i2c. I'm using MCC with pic 18F27K40. The PIC has and errata but I don't think is related with I2C. When I try to talk with a EEPROM over i2c, using I2C1_MasterWrite, che I2C_Flag is always in message pending. static uint16_t address = 0x90; static uint8_t length = 1; static uint8_t command = 0, data = 0; static I2C1_MESSAGE_STATUS I2C_Wflag, I2C_Rflag; /* Start a I2C Write operation. */ I2C1_MasterWrite( &command, length,address, &I2C_Wflag); if (I2C_Wflag == I2C1_MESSAGE_FAIL) while (1) // Something wrong LED=1; while (I2C_Wflag != I2C1_MESSAGE_COMPLETE); LED=0; __delay_ms(100); LED=1; __delay_ms(100); Someone know why this is happening? Thanks a lot! |
你好!同样的问题与MCC生成的代码,这为我解决了:HTTP://www. McCHIP.COM/FUMMS/M10334 4ASPXU可以给出一个Tr.You.
以上来自于百度翻译 以下为原文 Hi ! Same issue with MCC generated code, This solved it for me : http://www.microchip.com/forums/m1033448.aspx You may give a try. Regards. |
5360 浏览 9 评论
2092 浏览 8 评论
1991 浏览 10 评论
3273 浏览 3 评论
2304 浏览 5 评论
868浏览 1评论
755浏览 1评论
698浏览 1评论
749浏览 0评论
643浏览 0评论
GMT+8, 2025-2-23 19:49 , Processed in 1.093840 second(s), Total 77, Slave 61 queries .
