很快,我被认为是创造者2.1,我认为这个创造者向前迈出了一大步。…模拟设备编辑器,橡皮筋模式,新的电源监控部件…我认为这是一个伟大的完成。其中,我发现一些新的特性是欧姆表。它可以简单地从右侧选项卡中选择Net并右击。估计电阻值将显示在测量点与指定节点之间。这对于了解模拟布线的电压降是有用的,用于精确测量。所以,我迫不及待地想试试创建者2.1的其他新特性。
以上来自于百度翻译 以下为原文 Immediately, I was favorited the CREATOR2.1 I think a major step forward in this CREATOR. ... Analog device editor, Rubber band mode, New Power Supervision Components ... I think that is a great finished up. Among them, I find some new feature that is a OHM METER. It can start simply select net from the right side tab and right-click. The estimate resistance value will shown between the measuring point with the specified node. This is useful to know the voltage drop of analog wirings, for precise measurements. So on, I can't wait to try out other new features of the CREATOR2.1 |
是的,欧姆表是另一个新的特性,帮助我们理解信号不是我们所期望的那样。硬件/软件协同开发的组合在行业中可能是独一无二的。
硬件支持在每个版本中都会越来越好,希望在不久的将来我们能在调试器中看到一些改进。 以上来自于百度翻译 以下为原文 Yeah, the Ohm Meter is another one of the new features helping to understand when signals aren't quite what we expect them to be. The combination of hardware/software co-development is probably unique in the industry. Hardware support is getting better with every release, I hope we will see some improvements in the debugger in a not too distant future, please. |
760个成员聚集在这个小组
加入小组2151 浏览 1 评论
1897 浏览 1 评论
3718 浏览 1 评论
1829 浏览 6 评论
1574 浏览 1 评论
778浏览 2评论
536浏览 2评论
482浏览 2评论
443浏览 2评论
1139浏览 2评论
GMT+8, 2025-2-24 11:53 , Processed in 0.724063 second(s), Total 41, Slave 36 queries .
