你喜欢Xilinx,
我在我的旧项目中使用Spartan-2 FPGA。 现在它需要更多的数字,截至目前这部分是活跃的,所以没有问题,但将来如果假设这个Spartan-2 getsobsolete那么如何解决这个问题。 由于这是较旧的项目,因此我们没有FPGA的任何源代码和功能。 我们只有编程文件(位文件/ Bin文件)。 如果Xilinx对此有所帮助,那将非常有用。 谢谢你的问候, Venkatesh Babu.N 以上来自于谷歌翻译 以下为原文 Hi Xilinx, I Am using Spartan-2 FPGA for my older project. Now it is required more number, as of now This part is Active so no issue, But in future if suppose this Spartan-2 gets obsolete then how to address this issue. Since this is older project we doesn't have any source code and functionality of the FPGA. we have only Programming file(Bit file/Bin file). If Xilinx helping on this it is very useful. Thanks With Regards, Venkatesh Babu.N |
坏消息是你必须从头开始重新设计。
没有更新的设备与Spartan 2具有比特流兼容(甚至引脚兼容),并且没有软件可以修改比特流以在更新的设备上工作。 好消息是,您已经足够早地发现问题以实际处理它 - 而不是在Xilinx向您发送“产品不再可用”电子邮件时感到恐慌。 Xilinx为您提供为期两年的通知期。 他们会宣布他们计划停止生产,然后一年后他们会宣布你需要下订单的最终订单,然后一年后他们就会停止接受这些芯片的任何订单。 我建议借此机会研究系统如何从更新的芯片中受益。 许多旧设计都有FPGA,专用处理器,可能是专用DSP等。如今,像Zynq这样的单个集成芯片可以完成所有这三个任务,从而降低成本和PCB空间。 在原帖中查看解决方案 以上来自于谷歌翻译 以下为原文 The bad news is that you're essentially going to have to recreate the design from scratch. There is no newer device that is bitstream-compatible (or even pin-compatible) with the Spartan 2, and there is no software that can modify the bitstream to work on a newer device. The good news is that you've found the issue early enough to actually deal with it - rather than panicking when Xilinx sends you the "product is no longer available" email. Xilinx gives you a two-year notice period. They'll announce that they're planning to stop production, then a year later they'll announce that you need to place final orders for the parts, and then a year after that they stop accepting any orders for those chips. I would suggest taking the opportunity to investigate how the system could benefit from a newer chip. Many old designs had an FPGA, a dedicated processor, maybe a dedicated DSP, etc. These days a single integrated chip like a Zynq can do all three roles, for much lower cost and PCB space. View solution in original post |
坏消息是你必须从头开始重新设计。
没有更新的设备与Spartan 2具有比特流兼容(甚至引脚兼容),并且没有软件可以修改比特流以在更新的设备上工作。 好消息是,您已经足够早地发现问题以实际处理它 - 而不是在Xilinx向您发送“产品不再可用”电子邮件时感到恐慌。 Xilinx为您提供为期两年的通知期。 他们会宣布他们计划停止生产,然后一年后他们会宣布你需要下订单的最终订单,然后一年后他们就会停止接受这些芯片的任何订单。 我建议借此机会研究系统如何从更新的芯片中受益。 许多旧设计都有FPGA,专用处理器,可能是专用DSP等。如今,像Zynq这样的单个集成芯片可以完成所有这三个任务,从而降低成本和PCB空间。 以上来自于谷歌翻译 以下为原文 The bad news is that you're essentially going to have to recreate the design from scratch. There is no newer device that is bitstream-compatible (or even pin-compatible) with the Spartan 2, and there is no software that can modify the bitstream to work on a newer device. The good news is that you've found the issue early enough to actually deal with it - rather than panicking when Xilinx sends you the "product is no longer available" email. Xilinx gives you a two-year notice period. They'll announce that they're planning to stop production, then a year later they'll announce that you need to place final orders for the parts, and then a year after that they stop accepting any orders for those chips. I would suggest taking the opportunity to investigate how the system could benefit from a newer chip. Many old designs had an FPGA, a dedicated processor, maybe a dedicated DSP, etc. These days a single integrated chip like a Zynq can do all three roles, for much lower cost and PCB space. |
2708 浏览 7 评论
3024 浏览 4 评论
2441 浏览 9 评论
3557 浏览 0 评论
2642 浏览 15 评论
3442浏览 1评论
852浏览 1评论
707浏览 1评论
GMT+8, 2025-7-19 09:14 , Processed in 1.342280 second(s), Total 77, Slave 61 queries .
