* N7609B高级实时模式的常见问题解答*问题:N7609B如何在场景中计算与可见卫星数量相关的总输出功率?
以上来自于谷歌翻译 以下为原文 *FAQs for N7609B Advanced Real-time Mode* Question: How does the N7609B calculate the total output power in relation to the number of visible satellites during a scenario? |
答:当您最初打开模拟时,“卫星设置”页面将更新“电源”列,以dBm显示每颗卫星的功率。
总输出功率将始终为此页面上显示的每颗卫星的功率值之和,并且会实时更新。 最初,这将等于“仪器”设置页面上的幅度设置。 例如,默认情景文件包含16颗卫星,默认仪器功率设置为-100 dBm,每颗卫星输出-112.04 dBm。 但是,如果您对任何卫星应用功率偏移,那么该卫星的功率将会改变,而其他卫星功率水平保持不变,并且总功率将不再等于“仪器”页面上的功率设置,因为它未更新 实时。 以上来自于谷歌翻译 以下为原文 Answer: When you initially turn on the simulation, the Satellite Settings page will update the “Power” column to show the power of each satellite in dBm. The total output power will always be the sum of the power values for each satellite shown on this page, which is updated in real-time. Initially this will be equal to the amplitude setting on the “Instrument” setup page. For example, with the default scenario file containing 16 satellites and the default Instrument power setting of -100 dBm, each satellite is outputting -112.04 dBm. But if you apply a power offset to any satellite, the power of that satellite will change while the other satellite power levels remain the same, and the total power will no longer equal the power setting on the “Instrument” page since that is not updated in real-time. |
1385 浏览 0 评论
2419 浏览 1 评论
2268 浏览 1 评论
2105 浏览 5 评论
3019 浏览 3 评论
1427浏览 1评论
827浏览 0评论
1196浏览 0评论
1385浏览 0评论
GMT+8, 2025-2-25 00:28 , Processed in 1.303654 second(s), Total 44, Slave 38 queries .
