大家好,
我正在用PSoC3芯片工作。第一次使用PSoC,我想知道可以将正弦波输入到PSoC内部的低通滤波器的模拟输入端吗?由于PSoC在3.3VDC下运行,正弦波将在1.5伏直流振荡,摆动约1VP/P。 这是允许的还是只模拟输入直流电平?此外,如果答案是肯定的,我可以发送一个正弦波到设备,可以输出我的PWM,并发送它通过一个内部积分器,并输出正弦波? 先谢谢你。 吉姆 以上来自于百度翻译 以下为原文 Hello all, I am working with a PSoc3 chip. First time using the PSoC, and I am wondering can I send a sine wave into an analog input to a low pass filter inside the PSoC? Since the PSoC is running at 3.3vdc the sine wave will canter on 1.5vdc and swing approximately 1vp/p. Is this allowable or is the analog input DC level only? Also, if the answer is YES that I can send a sinewave into the device, can I take th eoutput of my PWM, and send it through an internal integrator and output a sine wave? Thank you in advance. Jim |
是的,你可以把正弦波发送到PSoC3,它的输入完全能够处理AcPosits(取决于电压水平高达几MHz)。但是你不能用你的信号在地面或VDDA以上,但是你的建议信号即使是3.3V的VDDA也会很好。
我认为没有内部积分器,但是你应该能够用惰性运算放大器和一些外部电容器/电阻器自己构建一个。或者你去实验和数字化的信号,并把它输入到数字滤波器… 以上来自于百度翻译 以下为原文 Yes, you can send in a sine wave to the PSoC3 - its inputs are perfectly capable to handle AC inputs (up to several MHz, depending on the voltage levels). But you cannot go below ground or above Vdda with your signal - but your proposed signal would be fine even with 3.3V Vdda. I think there is no internal integrator, but you should be able to build one by yourself using the inernal OpAmps and some external capacitors / resistors. Or you go experimental and digitize the signal and feed it into the digital filter... |
始终检查数据表以查看是否在使用R—R输入
和输出,否则有限的CM范围将限制PK-PK摆动。 为了将信号偏移到PSoC,可以将AC耦合到一个简单的分频器。 将偏移量提供给输入。或者您可以使用以下消除 耦合帽,只使用两个R - HTTP//Engigdio.COM/Actudio/USE-Excel计算器D电平移位器电阻值 Excel电子表格附加到Calc值。 对于PWM积分器来说,一个简单的RC网络是多余的。本AP注释讨论了 在RC滤波器中的稳定时间和纹波。 HTTP://www. Ti.COM/LIT/AN/SLYT076/SLYT076PDF 问候,Dana。 121232.XLS 12 K 以上来自于百度翻译 以下为原文 Always examine data sheets to see if you are working withg R-R Inputs and outputs, otherwise limited CM range will limit pk-pk swings. To offset signals into PSOC you can ac couple to a simple divider that supplies the offset to the input. Or you can use the following which eliminates couplig cap, just uses two R's - http://electronicdesign.com/analog/use-excel-calculate-d-level-shifter-resistor-values Excel spreadsheet to calc values attached. For PWM integrator, a simple RC network offten surfices. This ap note discusses tradeoff of settling time and ripple in the RC filter. http://www.ti.com/lit/an/slyt076/slyt076.pdf Regards, Dana.
760个成员聚集在这个小组
加入小组2151 浏览 1 评论
1897 浏览 1 评论
3718 浏览 1 评论
1829 浏览 6 评论
1574 浏览 1 评论
778浏览 2评论
536浏览 2评论
482浏览 2评论
443浏览 2评论
1139浏览 2评论
GMT+8, 2025-2-24 18:19 , Processed in 0.961720 second(s), Total 76, Slave 60 queries .
