嗨,
我使用LSM6DSL和SMT32L476。我的问题与睡眠/不活动中断有关。 我能够在睡眠和唤醒中断时使用LSM6DSL。 但是,可以使用此中断(睡眠/不活动)并禁用加速度计采样率自动降低至13 Hz选项。 我尝试将TAP_CFG(58h)设置为0x80(INACT_EN = b00),但不再生成中断。 有人可以告诉我是否有可能,如果是这样的话? 谢谢, #lsm6dsl #inactivity ## interrupt 以上来自于谷歌翻译 以下为原文 Hi, I am using the LSM6DSL with a SMT32L476. My question is in relation to the Sleep/inactivity interrupt. I am able to use the LSM6DSL in both sleep and wake up interruption. However is it possible to use this interrupt (Sleep/inactivity) and disable the automatic decrease of the accelerometer sampling rate to 13 Hz option. I tried to set TAP_CFG (58h) to 0x80 (INACT_EN = b00) but the interrupts are not generated anymore. Can someone please tell me if it is possible and if it is how to ? Thanks, #lsm6dsl #inactivity ##interrupt |
使用不活动功能的原因是通过降低采样率来降低功耗,因此禁用此采样率降低是没有意义的。您可以使用唤醒中断进行活动检测。
- 向TAP_CFG写入90h //启用中断并应用高通数字滤波器;已锁定//模式已禁用 - 写00h到WAKE_UP_DUR //没有持续时间 - 将02h写入WAKE_UP_THS //设置唤醒阈值 - 将20h写入MD1_CFG //唤醒中断驱动至INT1引脚 以上来自于谷歌翻译 以下为原文 The reason to use inactivity function is to reduce the power consumption by decreasing the sampling rate, so it doesn't make sense to disable this sampling rate reduction. You can use wake-up interrupt for activity detection. - Write 90h to TAP_CFG // Enable interrupts and apply high-pass digital filter; latched // mode disabled - Write 00h to WAKE_UP_DUR // No duration - Write 02h to WAKE_UP_THS // Set wake-up threshold - Write 20h to MD1_CFG // Wake-up interrupt driven to INT1 pin |
你好Miroslav B,
谢谢你有时间回答我。 我从加速度传感器读取永久性数据(208Hz)(也用作Hub以添加各种其他传感器) 当发生不活动检测时(从加速度计),我必须首先管理使用传感器数据的算法。在某些情况下,即使发生了这种睡眠模式,我也不必“接受”这种睡眠模式(取决于Uc和用户状态)。通过自我管理加速度计的采样率,我可以做任何我想做的事情。 有没有办法禁用这个额外的功能(自动降低采样率),但仍然使用不活动检测? 我对唤醒活动没有任何问题。每件事都按照我的预期运作。 谢谢 以上来自于谷歌翻译 以下为原文 Hi Miroslav B, Thanks for having time to answer to me. I read in permanence data (208Hz) from accelerometers sensors (used as Hub too to add various other sensors) When an inactivity detection occurred (From accelerometer) I have to manage my algorithms which use the data from sensors first. In certain case I don't have to 'accept' this sleep mode even if it is occurred (depending of Uc and user state). By managing myself the sampling rate of the accelerometer I can do whatever I want. Is there any way to disable this extra feature (Auto decreasing the sample rate) but still use the inactivity detection? I don't have any problem with the wake up activity. Every thing works as I expected. Thanks |
2783 浏览 1 评论
3252 浏览 1 评论
1826 浏览 1 评论
3672 浏览 6 评论
6065 浏览 21 评论
1348浏览 4评论
对H747I-DISCO写程序时将CN2的st-link复用为usart1,再次烧录时无法检测到stlink怎么解决?
373浏览 2评论
STM32G474RE芯片只是串口发个数据就发烫严重是怎么回事?
468浏览 2评论
STM32处理增量式编码器Z信号如何判断中断是正转的还是反向转的?
292浏览 2评论
使用STM32F407VET6的USB2.0功能,发现ctl后芯片无数据返回,是什么原因可能导致的呢?
216浏览 2评论
GMT+8, 2025-1-13 01:19 , Processed in 0.834326 second(s), Total 46, Slave 41 queries .
