我读了几篇关于FX3编程切换到不同速度模式的文章,比如说,我们有一个FX3 DEV板,可以插入XHCI端口(支持超高速)。
在这里,我们想要的是将FX3 DEV板切换到三种不同的速度模式(插入XHCI端口),从一个POST我知道它可以在HS和SS之间切换,而不是FS,CyPress能修复这个吗? 谢谢, 亨利 以上来自于百度翻译 以下为原文 I read several posts about FX3 programmatically switch to different speed modes, let's say we have a FX3 dev board that plugs into a xHCI port (support super speed). Here, what we want is to have FX3 dev board switched to three different speed modes ( plug into xHCI port), from one of the post I know that it can be switch between HS and SS, but not FS, can Cypress fix this? Thanks, Henry |
请告诉我你方要求的使用情况。
当做, 西克里希纳。 以上来自于百度翻译 以下为原文 Please let me know the use case of your requirement. Regards, sai krishna. |
编辑:
SDK具有防止FX3从高速设备连接一个API函数如下。 注意:在连接状态API之前调用这个API。 示例代码: /*使USB全速连接。*/ APIRSTATSION = CYU3PUS BulfFulfSurvivin(Cyress); 如果(ApRestStand)!= CYU-U3PY成功 { cyu3pdebugprint(4,“全速连接失败,错误代码= %dn”,apiretstatus); CyFxAppErrorHandler(ApRestStand); } / *连接USB引脚的高速运行的残疾人。*/ ApIdReStase= CYU3pCeltT态(Cytru,CyFalse); 如果(ApRestStand)!= CYU-U3PY成功 { cyu3pdebugprint(4,USB连接失败,错误代码= %dn”,apiretstatus); CyFxAppErrorHandler(ApRestStand); } 当做, 诺里基 以上来自于百度翻译 以下为原文 Edited: The SDK has an API function to prevent FX3 from connecting as a High-Speed device as follows. NOTE: Call this API before ConnectState API. Example Code: /* Make USB Full Speed Connection. */ apiRetStatus = CyU3PU***ForceFullSpeed(CyTrue); if (apiRetStatus != CY_U3P_SUCCESS) { CyU3PDebugPrint (4, "Full Speed Conn Failed, Error code = %dn", apiRetStatus); CyFxAppErrorHandler(apiRetStatus); } /* Connect the USB Pins with super speed operation DISABLED. */ apiRetStatus = CyU3PConnectState(CyTrue, CyFalse); if (apiRetStatus != CY_U3P_SUCCESS) { CyU3PDebugPrint (4, "USB Connect failed, Error code = %dn", apiRetStatus); CyFxAppErrorHandler(apiRetStatus); } Regards, Noriaki |
750个成员聚集在这个小组
加入小组2055 浏览 1 评论
1811 浏览 1 评论
3622 浏览 1 评论
1747 浏览 6 评论
1499 浏览 1 评论
484浏览 2评论
339浏览 2评论
401浏览 2评论
343浏览 2评论
836浏览 2评论
GMT+8, 2024-11-10 16:19 , Processed in 0.602068 second(s), Total 47, Slave 42 queries .
