大家好,
我试着了解LIS3DSH加速度计的实际可用分辨率是多少,因为我需要对其进行评估以进行透视测量。 从数据表我可以读取PSD = 150ug / sqrt(Hz)@ ODR = 100 Hz然后BW = 50 Hz 对于带有单极点滤波器的模拟输出,总噪声可以计算为PSD * SQRT(1.57 * BW),假设使用相同的计算我们有150ug * SQRT(78.5)= 1.33mg,灵敏度等于0.06 mg /数字@±2g我们有: 1.33mg / 0.06mg /位= 22.16位错误,然后理论上的16位我们应该有65536 / 22.16 = 2957.4位,大约相当于最终分辨率的11-12位。 我恳请问这是一种正确的模式,通过考虑噪音的影响或者如果我错过了一些点来估计真实的最终分辨率,那么可能是执行此计算的正确方法。 希望有人能指出我正确的方向。 在此先感谢 最好的祝福 法比奥 以上来自于谷歌翻译 以下为原文 Hi all, I'm try to understand what can be the real usable resolution of the LIS3DSH accelerometer because I need to evaluate it for inclometric measurements. From the datasheet I can read a PSD=150ug/sqrt(Hz) @ ODR=100 Hz then BW=50 Hz For a analog output with one single pole filter the overall noise can be calculated as PSD*SQRT(1.57*BW),supposing to use same calculation we have 150ug*SQRT(78.5)=1.33mg, having a sensitivity equal to 0.06 mg/digit @ ±2g we have: 1.33mg/0.06 mg/digit = 22.16 digit of error then instead the theoretical 16 bit we should have 65536/22.16=2957.4 digit which is approx equivalent to 11-12 bit of final resolution. I kindly ask if this is a correct mode to estimate the real final resolution by taking in account the effect of the noise or if I missing some point and then what can be the correct way to perform this calculation. Hope someone can point me in the correct direction. Thanks in advance and best regards Fabio |
2906 浏览 1 评论
3290 浏览 1 评论
1873 浏览 1 评论
3726 浏览 6 评论
6136 浏览 21 评论
STM32G070 UART串口,低波特率传送数据时,TIMER出现严重延时现象如何解决?
24浏览 4评论
STM32H7打开DCache后,出现了串口接收信息为空的现象,是哪里出了问题?
13浏览 4评论
用NANO STM32F103RBT6的开发板烧录不了是哪里出了问题?
10浏览 4评论
4浏览 4评论
stm32mp135使用官方SDK交叉编译工具链,编译的时候却找不到头文件怎么解决?
12浏览 3评论
GMT+8, 2025-3-10 22:25 , Processed in 0.738772 second(s), Total 79, Slave 63 queries .
