我想使用“EZ-USB FX2LPμUSB微控制器”从从28335个CPU到XtiF区0的数据传输模式。
我的设置就像 -我有16条专用数据线连接到FD〔0〕-〔15〕。 -FA〔0〕-〔1〕用于访问FIFO的地址。 - 24 MHz外部CLK到IFCK,其他信号类似/SLC,SLD,SLWR,/SLUE,PCKNADE,标志连接到我的设置 我的问题是:为了编写读写固件,我不知道如何使用这个设置来控制USB数据传输。 Ques: 1。一些身体可以帮助在FX2LP配置从属模式…? 2。如何在USB控制器上写寄存器,以便配置端点RAM? 三。我读写的假设是,FIFO地址可以使用FA〔0〕-〔1〕信号{ 2 ^ 2=4个FIFO地址512个字节}来存取,是正确的吗? 配置USB控制器需要紧急帮助,这样我可以使用数据的读取和使用的EZ-USB FX2LP™USB单片机写的功能”。 以上来自于百度翻译 以下为原文 I want to use the 'EZ-USB FX2LP™ USB Microcontroller' in the slave mode for data transfer from a 28335 CPU over its xintf zone 0. My setup is like - - I have 16 dedicated data lines connected to the FD[0]-[15] - FA[0]-[1] is used for access the address of the FIFO - 24 MHz external clck to IFCK, other signals like /SLCS, SLRD, SLWR, /SLOE, PCKTEND, Flags are connected to my setup My Problem: In order to write the read and write firmware, I am not sure how to control the USB data transfer using this setup. Ques: 1. Can some body help in configuring the FX2LP in slave mode..? 2. How to write the Registers on the USB controller, in order to configure the End Point RAM..? 3. My assumption for Reading and Writing is that, the FIFO addresses can be accessed using the FA[0]-[1] signals {2^2 = 4 FIFO address of 512 bytes each}, is it correct..? Need urgent help in configuring the USB controller, so that i can use the data read and write functionality using the 'EZ-USB FX2LP™ USB Microcontroller'. |
762个成员聚集在这个小组
加入小组2185 浏览 1 评论
1934 浏览 1 评论
3754 浏览 1 评论
1857 浏览 6 评论
1600 浏览 1 评论
1007浏览 2评论
666浏览 2评论
511浏览 2评论
479浏览 2评论
1351浏览 2评论
GMT+8, 2025-4-7 06:19 , Processed in 0.753655 second(s), Total 42, Slave 37 queries .
