扫一扫,分享给好友
嗨,
我是新手,我想知道是否有XC95144XL CPLD的评估板。 谢谢, karthick。 以上来自于谷歌翻译 以下为原文 Hi, I am a newbie, I would like to know if there are evaluation boards for XC95144XL CPLD. Thanks, karthick. |
这是一个非常古老,过时的设备。
我只用这台设备找到了2块板,两家公司早就不见了。 祝你好运! http://www.fpga-faq.com/FPGA_Boards.shtml 我建议你访问digilent并查看他们的FPGA卡.. 不要忘记通过接受帖子作为解决方案来尽可能地关闭线程。 以上来自于谷歌翻译 以下为原文 This is a very old, obsolete device. I only found 2 boards with this device, and both companies are long gone. good luck! http://www.fpga-faq.com/FPGA_Boards.shtml I recommend you visit digilent and look at their FPGA cards.. Don't forget to close a thread when possible by accepting a post as a solution. |
我不知道,但你可以轻松地制作一个。
CPLD几乎不需要外部硬件 - 对于基本系统,您只需要一个电源和一个JTAG接头(振荡器是可选的;取决于您是否打算从外部时钟驱动它)。 我刚刚购买了这块PCB,将这块芯片焊接到它上面,并将这个芯片与这个3.3V稳压器一起插入这个面包板。 即时评估板,可访问设备上的每个引脚。 以上来自于谷歌翻译 以下为原文 I'm not aware of any, but you could make one pretty easily. CPLDs need almost no external hardware - for a basic system you just need a power supply and a JTAG header (oscillator is optional; depends whether you intend to drive it from an external clock or not). I'd just buy this PCB, solder this chip to it, and plug it into this breadboard along with this 3.3V regulator. Instant evaluation board, with access to every pin on the device. |
2468 浏览 7 评论
2855 浏览 4 评论
2317 浏览 9 评论
3400 浏览 0 评论
2498 浏览 15 评论
2110浏览 1评论
640浏览 1评论
498浏览 1评论
2047浏览 0评论
778浏览 0评论
GMT+8, 2025-1-31 17:09 , Processed in 1.170483 second(s), Total 44, Slave 39 queries .
