我们注意到加速度计在一段时间(10+)后停止采样。当发生这种情况时,唯一的解决方法是在REG4中写入0x0,然后重写原始值0x37。有人遇到过类似的问题吗?
干杯, #采样冻结 以上来自于谷歌翻译 以下为原文 We have noticed that the accelerometer stops sampling after some time (10+). When that happens, the only work around is to write 0x0 in REG4, and then re-writing the original value of 0x37. Anyone has encountered a similar problem? Cheers, #sampling-freeze |
5个回答
你有推荐靠近传感器的阻塞电容吗?
以上来自于谷歌翻译 以下为原文 Do you have recomended blocking capacitors close to the sensor? |
我怀疑Javier报告的解决方案是否可行,将这些值写入CTRL_REG4是没有意义的。有意义的是将值写入CTRL_REG1寄存器,因此它将停止并启动传感器。
很难推出这类问题。 您可以检查传感器所连接的总线上的SPI通信是否正确,因为如果CS信号未选择传感器,则它正在监听通信并期望I2C。因此,您必须确保SPI通信不会产生一些可以通过I2C接口捕获的模式。 您还可以通过向SPC引脚发送一堆时钟脉冲来尝试从传感器冻结中恢复。 以上来自于谷歌翻译 以下为原文 I doubt the solution reported by Javier could work, it doesn't make sense to write these values to CTRL_REG4. What could make sense is to write the values into CTRL_REG1 register, so it will stop and start the sensor. It is difficult to debut this kind of issue. You can check that the SPI communication on the bus where the sensor is connected is proper, because if the sensor is not selected by CS signal it is listening the communication and expecting I2C. So you must be sure that the SPI communication doesn't create some patter which can be capture by I2C interface. You can also try to recover from the sensor freeze by sending bunch of clock pulses to SPC pin. |
好吧,数据在下降时钟边沿变化,关于PCB,寄生效应和时序,此时在从机端识别出什么。由于两个边缘可能“同时”发生,因此一个人不能特别说它不会发生。
但是,如果你愿意,我可以附上一个寄存器转储,没问题。这需要一些时间,因为我的设备目前正在建设中,还有一些其他东西,正如我所说,因为我解决了我的SPI问题,所以整个问题可能已经消失。 我非常感谢你的兴趣! 以上来自于谷歌翻译 以下为原文 Well, the Data changes on the falling Clock edge, its about the PCB, parasitics and timing, what is recognized on the slave side at this point. Since both edges may happen 'at the same time', one cant specificly say that it doesnt happen. But yes, i can attatch a register dump if you like, no problem. It will take some time, since my device is currently under construction with some other stuff, and as I said, since i resolved my SPI-problem, it is possible that the whole issue has gone away. I thank you a lot for you interest! |
2764 浏览 1 评论
3248 浏览 1 评论
1821 浏览 1 评论
3663 浏览 6 评论
6055 浏览 21 评论
1346浏览 4评论
209浏览 3评论
对H747I-DISCO写程序时将CN2的st-link复用为usart1,再次烧录时无法检测到stlink怎么解决?
364浏览 2评论
STM32G474RE芯片只是串口发个数据就发烫严重是怎么回事?
458浏览 2评论
STM32处理增量式编码器Z信号如何判断中断是正转的还是反向转的?
281浏览 2评论
GMT+8, 2025-1-4 17:35 , Processed in 1.504700 second(s), Total 91, Slave 73 queries .
