我在86100C上看到了一条错误消息“无效的硬件配置:触发路径”。
它昨天没有任何问题,但它从今天早上开始显示此消息。 由于未检测到触发信号,我无法捕获任何信号。 有没有人看到同样的消息? 谢谢你的帮助。 以上来自于谷歌翻译 以下为原文 I've seen an error message, "Invalid hardware configuration: Trigger path" on my 86100C. It worked without any problem yesterday, but it start showing this message from this morning. Since the trigger signal is not detected, I cannot capture any signal. Has anyone see same message? Thank you for your any help. |
您好Skuma,您对此问题有任何回复吗?
很可能其中一个RF开关或主机中的计数器板没有响应,因此大型机无法识别它是一个选项001,需要进行维修。 如果您已将其送去维修,您能告诉我序列号,以便查询维修详情吗? 以上来自于谷歌翻译 以下为原文 Hello Skuma, Did you get any reply on this question? It is most likely one of the RF switches or the counter board in the mainframe is not responding so the mainframe does not recoginze it is an option 001 and would need to go in for repair. If you have sent it in for repair, can you let me know the serial number so I can look up the repair details? |
1299 浏览 0 评论
2379 浏览 1 评论
2199 浏览 1 评论
2068 浏览 5 评论
2955 浏览 3 评论
1143浏览 1评论
760浏览 0评论
952浏览 0评论
1299浏览 0评论
GMT+8, 2024-12-29 14:46 , Processed in 1.511129 second(s), Total 77, Slave 61 queries .
